I had U-Haul install an extension for trailer lights in my spare tire compartment using the factory pre-installed harness. Initially, the lights worked fine, then after a few months, all lights were out. The U-Haul folks checked their work with a voltmeter and said its fine, that there had to be a problem "upstream", e.g. a fuse. I looked at the fuse boxes under the hood and under the dash, and a) there were no fuses labeled "trailer", or anything like that, and b) there were no blown fuses in either box. I went to the Honda dealer and they said they'd work on it for a fee, since it isn't waranteed after U-Haul touches it. So I decided to keep working on it on my own. Honda said look for a separate fuse near the clutch pedal, and I demonstrated to them, in the parking lot, that there was no fuse there. Then they said I'd have to look behind the internal wall panels in the rear, that it must be there, but they didn't know which side. I've pulled out the driver side wall and traced the wiring from the trailer light extension up to about the drivers seat, and have found no fuse.
I don't see any reason to pull open the passenger side wall since the wires are clearly on the driver's side.
Anyone know where the fuse is?
Thanks,
Bob
Thanks,
Bob
