Replacing the serpentine belt—how-to - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Maintenance and Service
Notices
Reply
Thread Tools Display Modes
Old 06-20-2005, 10:48 PM   #1
Box4Rox
EOC Rank: Carbon
2003 4WD EX AT
Sunset Orange Pearl (SOP)
Box4Rox's Avatar
I finally attempted the drive belt replacement as part of a little preventative maintenance (66,300 miles !!) . The ONLY way I can see it being done is with a special tool designed to manipulate the Serpentine belt tensioner . . . I tried everything else; impossible access and leverage issues prevented normal tools (sockets, open ends, box ends, ratchets, breaker bars, ouji boards, etc.) from even getting close.
I ended up buying the tool at Pep Boys for 40 bucks; Lisle model 57900 http://shop.store.yahoo.com/bradystools/betoseli57.html
Purchased the belt from Majestic Honda (item #12 - $26.60)
http://www.hondaautomotiveparts.com/...++++COMPRESSOR
I don’t know why Honda doesn’t supply a belt routing diagram under the hood like most manufacturers so I made my own. I suspect because this removal is so tricky (and dangerous = missing fingers !!) that they don’t want DIY’ers messing with it. Nothing about it in the manual either, but here’s what you’re up against . . . :)
(Sorry, I don’t know what it looks like without the AC option)
Last edited by Box4Rox; 09-10-2005 at 08:41 PM. Reason: swapped attachment for link
Box4Rox is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-20-2005, 10:50 PM   #2
Box4Rox
EOC Rank: Carbon
2003 4WD EX AT
Box4Rox's Avatar
Re: Replacing the drive belt - how to
The procedure is fairly straight forward:
Need:
• Replacement belt P/N 38920-PZD-A01
• Serpentine Belt Removal Tool (with adjustable offset) and 14mm 6 sided socket
• 10 mm open end wrench
1. Turn front wheels hard right (or remove RF wheel) and remove the plastic access panel to exposed the main crank pulley
2. Using a 10mm wrench loosen (but don’t completely remove) the bolt holding the power steering line clamp on the fender wall. Moving the clamp and steel tubing around later on will help with a tight clearance when attaching the tensioner tool to the pulley bolt.
3. Assemble the tensioner tool with an angle (using the extension) and shallow (again, for clearance issues) 14mm six sided socket – see picture below
Last edited by Box4Rox; 09-10-2005 at 08:38 PM. Reason: swapped attachment for link
Old 06-20-2005, 10:52 PM   #3
Box4Rox
EOC Rank: Carbon
2003 4WD EX AT
Box4Rox's Avatar
Procedure continued -
4. Attach the tool using the 14mm socket to the center bolt on the tensioner (yes, it is really tight in there).
5. Pull the tool towards the front of the E and the tensioner will rotate towards the rear and remove tension from the belt.
6. Slide the belt off the alternator pulley first and then the tensioner and S-L-O-W-L-Y let the tool and tensioner return to a neutral position.
(when installing a belt, the alternator pulley will be the last pulley that you slide the belt onto . . .)
7. Remove the belt from the other pulleys
Reverse the process for installation.
Having a helper and extra set of hands really helps on installation; just make sure everyone is communicating “where hands are” when the pulling tension via the tool. :)
Last edited by Box4Rox; 09-10-2005 at 08:35 PM. Reason: swapped attachment for link
Old 06-21-2005, 12:44 AM   #4
LEGO MY E
EOC Rank: Carbon
2004 4WD LX
Fiji Blue Pearl (FBP)
LEGO MY E's Avatar
Talking Re: Replacing the drive belt - how to
Cool, thanks for the tips (and pictures) Box4Rox!! :)
It's good to see fellow EOC members who aren't afraid to roll up their sleeves and maintain their own vehicle - VERY Cool!
LEGO MY E is offline   Reply With Quote Quick reply to this message
Old 06-21-2005, 07:41 AM   #5
Damien8086
EOC Rank: Helium
2004 4WD EX AT
Nighthawk Black Pearl (NBP)
Damien8086's Avatar
Send a message via AIM to Damien8086 Send a message via Yahoo to Damien8086
Great thread... I'm only at 10k miles so I don't need to do this yet, but when it is time I will definitely be looking this thread up. I need to do this on my Camaro as well - 216k miles and still going
Damien8086 is offline   Reply With Quote Quick reply to this message
Old 06-21-2005, 08:14 AM   #6
James_in_Baltimore
EOC Rank: Helium
2005 4WD EX
Magnesium Metallic (MM)
James_in_Baltimore's Avatar
Great pictures and instructions. I am nowhere near having to do it yet, but like damien, will be looking this thread up when the time comes. Thanks for the effort!
__________________
James
2005 EX 4WD MT - MM
James_in_Baltimore is offline   Reply With Quote Quick reply to this message
Old 06-21-2005, 10:46 AM   #7
prior8t2000
EOC Rank: Oxygen
2004 4WD EX
Satin Silver Metallic (SSM)
prior8t2000's Avatar
Send a message via Yahoo to prior8t2000
Very interesting, I see alot of attention went to just getting the tools.
Thinking - What does the dealer charge for this. Tanks for the pic's.
__________________
2004 SSM I like it Low and Slow, sometimes Fast
2004 White w/Racing Stripes, w/LED lights, Deluxe TearDrop
MODs - SS Ingen CatBk, SS Clear Brake Lines, UHall III, 12" LCD, PS2, 1500invtr, Yellow Top, Ingen Dampner, K&N SRA, A01 filters, OEM fogs, 6000k HID's w/white HALO's, Compl. in/out LED's, 2008 SC Front Seats, 2008 SC Blk Panels, PDL, 18" SC Rims, SC rear air deflector. OEM OPT. Leather Wheel Cover, 80gIPOD, GPS, LOJACK,.
prior8t2000 is offline   Reply With Quote Quick reply to this message
Old 06-22-2005, 07:20 PM   #8
j_m_m
EOC Rank: Helium
2003 4WD EX
Send a message via Yahoo to j_m_m
I know it would cost about 90 bucks with tax to have it done at a Quickey Lube...I used to work in one. Do you know what size the belt is? I know it has 7 ribs but don't know the length. You could save some money if you bought a different brand of belt. Just a thought. I would go with the OEM myself.
__________________
"Weaseling out of things is what separates us from the animals... except for the weasel....." -HJS
j_m_m is offline   Reply With Quote Quick reply to this message
Old 07-01-2005, 02:31 PM   #9
RainDriver
EOC Rank: Oxygen
2004 2WD DX MT
RainDriver's Avatar
Best DIY tip on the site so far...glad to see your mileage is so far ahead of mine, DO PLEASE continue to blaze those trails!
__________________
'04 blue E base 5-spd
'93 VW T4 2.4D Karmann Gipsy
'64 Honda 305 Dream Touring
RainDriver is offline   Reply With Quote Quick reply to this message
Old 08-16-2006, 12:34 PM   #10
edmonds59
EOC Rank: Hydrogen
2003 4WD EX AT
serpentine belt tool
Say, that tensioner adjuster tool looks like something a crafty person might put together with Home Depot parts for about 10 bucks. Any chance that someone who has bought one could provide some simple dimensions of the thing? And earn the gratitude of cheapskates everywhere?
At 40 bucks for the tool it's on the threshold of just letting the dealer do it (and taking responsibility for getting it right, and having someone else jam their pinkies into greasy metal spaces, etc.) Thanks.
edmonds59 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Tags
serpentine belt , tensioner
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Strange serpentine belt wear? E4EveryOne Maintenance and Service 8 01-24-2011 05:10 PM
serpentine belt replacement buzzinhonolulu Hawaii Element Owners 2 11-02-2010 09:15 AM
Serpentine Belt Question ElementXofXMusic Maintenance and Service 1 02-14-2010 12:22 AM
Serpentine Belt Deterioration millerjerr Maintenance and Service 5 08-21-2009 01:16 AM
Serpentine Belt/Tensioner Johnnylightning Under The Hood / Performance 25 09-07-2007 04:58 PM
