| Register | FAQ / How To's | Members List | Honda Dealers | Honda Club Store | EOC Calendar | Search | Today's Posts | Mark Forums Read |
| Notices |
Thread Tools | Display Modes |
#1 |
EOC Rank: Oxygen
2004
4WD EX AT
Satin Silver Metallic (SSM) Join Date: Mar 2005
Mr. Clean AutoDry Pro
It seems a Pro version has come out and has some improvements to the older version. I would not know as I do not have either.
I did a quick search and only found about 4 threads talking directly about the AutoDry system. Shen seems to love his original as did the others in the other threads I found. This has serious pushed me to run out and buy one next weekend for the weekly wash (almost every saturday or sunday since I bought the E in March 05). I do like washing the E and use the Eagle 1 Wax as you Dry every time. I think that stuff is fantastic. I was never much into keeping my old vehicles cleans much less waxed. Anyway, I was wondering for those that have either the original or the new Pro version, do you think I will still be able to use the Eagle 1 after washing and rinsing with the AutoDry? Does the water sheet off to fast and dry the vehicle too quickly to use the Wax as you Dry stuff??
__________________
SSMEXAWDAUTO HONDA:Carpets, Cargo Liner & Cover, SplashGuards, Leather Wheel Cover, foglights, SC Rims After-Market:Paint Matched Rear Spoiler, Lund Bug Deflector, AVS Vent Visors, Carbon Fiber console decals, Headrest Shocks, SilverStar Lightbulbs, Cloud-Rider Grille, ProClip iPod dash-mount, Aluminum Pedals, 235/55/R18 Alenzas Mods:Pilot Steering wheel w/ Radio Controls, Aux Fuse Block, Internal secondary aux cable, Internal Belkin iPod cable, Acura Flip key |
#2 |
EOC Rank: Oxygen
2005
4WD EX AT
Rallye Red (RR) Join Date: Feb 2005
Re: Mr. Clean AutoDry Pro
I have the original, I would think your able to use the eagle one. I use eagle one but haven't used the 2 systems together. Well it dry's about as fast as it would without the autodry system. It just runs the water thru a filter that keeps the water spots from forming. I usually use the auto dry when I need a quick wash and can walk away from it or when I'm going to pull it in the garage and let it sit overnight to wax in the morning. I usually use the eagle one at the local coin op car wash and put it on in the parking lot.
__________________
We love our E's !! ___ We are A 2 E family also ! 2nd E 2003 DX EBP |
#3 |
EOC Rank: Oxygen
2004
4WD EX
Sunset Orange Pearl (SOP) Join Date: Feb 2005
I bought the pro model but returned it after using it once. I didn't end up seeing any time savings at all, in fact it took longer. The main advantage of the pro over the regular is supposed to be the new jet spray to "power" off dirt and road grime, etc, etc. In practice, the jet spray ended up being what I was imagining the regular spray should be. It couldn't really take off anything that my regular spray nozzle wouldn't. Trusting the jet spray probably added the most time to the wash.
The accessories are also pretty cheap. If you are thinking of trying the autodry system, I'd suggest finding one of the regular ones on sale. Me, I'm gonna go with the Eagle Bucketless, Wax as you dry and a hose with a regular garden sprayer. |
#4 |
EOC Rank: Helium
2005
4WD EX
I have the original. Ive never replaced the filter, it never real dried for me so i didn't see the use in another 5 bucks for it to do nothing again. But I do use it as a bucket alterinative.
__________________
'05EX4x4SOP 2/1/05 |
#5 |
EOC Rank: Oxygen
2004
4WD EX AT
Thanks for the replies guys....
I took your advice and picked up the original tonight on the way home at AutoZone. It was only $17.88, what a bargain. I also picked up a brush for cleaning the rims, a microfiber wash mit, new bottle of new Eagle1 Wax as you Dry (blue bottle), Eagle1 Tire shine, and a refill of the dryer cartridge. Total for everything was only $44 which is cheaper than what the Pro AutoDry is selling for. Washed the car after I mowed the yard (damn busy night for me). I guess it dried faster, because as I was using the Wax as you Dry on the passenger side the driver side was completely dry before I got to it. Not sure on the "spotless" since I am following up with the Eagle1. Either way I figure for $18 it is not that bad for the experiment.
__________________
#6 |
EOC Rank: Helium
2004
4WD EX AT
Shoreline Mist Metallic (SMM) Join Date: Aug 2004
The Auto dry doesn't actually dry anything. It removes impurities from the water so you can let your car drip or air dry without leaving spots. If you are imediately wiping down your car with quick detailer or wax as you dry there is no point in using an autodry because you are wiping away any waterbourne crud anyhow. I suppose it's useful if you have really high mineral content in your water. A bottle of quick detailer and a microfiber are cheaper in the long-run. Just wash with the hose.
__________________
04 SMM EX AUTO Power Lumbar, Steering Wheel Radio Controls, Extra Always-on Outlet, Side Marker Turn Signals, Lund Bug Deflector, Interlocking Rear Mats, Bridgestone H/L Alenza P215/70-R16
#7 |
EOC Rank: Helium
2005
2WD EX
Magnesium Metallic (MM) Join Date: Jul 2005
I've got the Pro edition. It was around $30 @ wally world.
It works OK. I use it sometimes. It can be a time saver, in my experience, but doubt it can be used effectively for its described purpose w/Wax-As-U-Dry. If you're going to Wax-As-U-Dry just dry the car normally that time & don't use the AutoDry setting as the filter has a limited life span--no reason to use it up if you're going to be drying the car anyway. |
#8 |
EOC Rank: Oxygen
2005
Nighthawk Black Pearl (NBP) |
I got the normal autodry, and worked great for me, even w/ the horrible hard water we have. Just dried the windows because I thought I'd have to...worked great though.
__________________
'05 Nighthawk Black Pearl LX4WD
Splash Guards, Home Depot Grille Guard, Red On Black 4WD emblem, Self Installed OEM Fogs, Self Installed XM Radio SkyFi2 w/ Hardwired Power Southern Utah Soon to come : PIE adapter for my SkyFi2, Panasonic 9" Drop Down DVD, Keyless, Billet Grille, Aries Guard Never put off until tomorrow what you can do today, because if you enjoy it today, you can do it again tomorrow. - James A Michener |
| Thread Tools | |
| Display Modes | |
