| Register | FAQ / How To's | Members List | Honda Dealers | Honda Club Store | EOC Calendar | Search | Today's Posts | Mark Forums Read |
| Notices |
Thread Tools | Display Modes |
#1 |
EOC Rank: Hydrogen
2005
4WD EX
Cargo Khaki (CK) Join Date: Feb 2005
many, many tar specks on door...
hi folks, a quickie -
just did a 2000 mile road trip (are these things a dream on a road trip or what?) and while washing today, noticed i have specks of tar all over my passenger door. i have tar remover, but is it safe to apply all over the entire door? i fear it will haze out the paint, or worse. i think it will be ok if i wax afterward, but want to get some peace of mind from any knowledgable folks here 1st. thanks in advance, rasmus |
#2 |
EOC Rank: Hydrogen
2005
2WD EX
Magnesium Metallic (MM) Join Date: Sep 2005
Re: many, many tar specks on door...
You can use tar remover, just do small sections at a time. It will remove whatever wax you have on there anyways so you will have to reapply wax. Another option is a clay bar if you don't trust the chemicals.
#3 |
EOC Rank: Iron
2004
4WD EX AT
Galapagos Green Metallic (GGM) Join Date: Nov 2004
Clay bar, absolutely.
Takes tar off with ease. Would help your entire rig, too. www.zainobros.com (see "Z-18 claybar," you get two for $1 The web page includes detailed instructions for claying. Good luck! |
#4 |
EOC Rank: Nitrogen
2006
4WD EXS AT
Atomic Blue Metallic (ABM) Join Date: Oct 2005
I just use the wax and tar remover that I got at Pep boys. Takes it off fast. Does not harm the paint. I have used the claybar, too much work. Eather way you have to re-wax !
__________________
Home made Grill guard, Blacked out lower front bumper trim,and Grill, Undercoating, Vent-Visors, Bug deflector, EOC Sticker, Honda Floor mats, Honda Wheel locks, Eurotech Engineering Fog lights, Dual tone Horn from a junk Caddie, Oh and the 2.98$ walfart windshield tint strip, that's got to go when EOC puts one out. U-haul hitch with factory Honda harness. Garmin GPSmap276C True, I've been IRV'ed , : Misfits waNNAbe's We love our E's !! ___ We are A 2 E family ! |
#5 | |
EOC Rank: Iron
2004
4WD EX AT
Quote:
#6 | |
EOC Rank: Neon
2003
4WD EX MT
Satin Silver Metallic (SSM) Join Date: Dec 2004
Quote:
We already covered the space-age polymer hype. :-P You should rewax after using a claybar. There is a difference between waxing and polishing. A polish is something applied to make a surface smooth or to remove slight imperfections. Kinda like a light sanding on wood. A wax is something applied to coat and protect the surface. I have checked out the Zaino website and they don't seem to differentiate between the two. I'm sure they are great products but it looks like they are specifically designed to make you buy multiple items. Z-18 claybar, then "The basic products you will need are Z1 or the new ZFX accelerator additive, Z2, Z5 (optional, but highly recommended), Z6 and Z7." If I put two to three coats of any wax on my car at any one time it'd be pretty glossy. By the way, where does it say that you don't have to reapply anything after using the claybar? The only place I found that discusses application is in the "ZAINO APPLICATION TIPS" section and it lists using the claybar before applying everything else. On the Z-18 claybar info page it even says.... "Z-18 ClayBar™ is highly recommended as the ultimate way to clean and prepare your car's finish prior to using the Zaino Show Car Polish system." and The final step #6. "When you're finished claying your car, you should wash it with Z-7 Show Car Wash to remove the lubricant film. Finally, seal your freshly cleaned paint with your choice of Z-2 Show Car Polish for Clear Coated Car Finishes, Z-3 Show Car Polish for Non-clear Coated Paint, or Z-5 Show Car Polish for Swirl Marks and Fine Scratches." Isn't that specifically saying that you should reapply the wax/polish (whatever) after using the claybar?
__________________
If it weren't for physics, and the cops, I'd be unstoppable! K&N Typhoon, Magnaflow, Grille-Tech, Painted Engine Covers/Strut Bar/Headlights, Stebel Nautilus Horn, SCA carpet, Storage Armrest, Wet Okole Seat Covers, CB, Window & Front Ventvisors, BFG TKO A/Ts, Hunter Guard, Aries Tail Guards, Thule Rack, Bike Racks & MOAB Basket. |
#7 |
EOC Rank: Iron
2004
4WD EX AT
I've been using Zaino for five years. That is how I know the claybar doesn't take the Zaino polish off.
I'm as sure of that as I am that my GGM is green. :wink: What a claybar does to your wax, I have no idea. As for this assertion of yours: "A polish is something applied to make a surface smooth or to remove slight imperfections. Kinda like a light sanding on wood." On that, you are wrong. You have mistaken polish -- at least, Zaino polish -- with rubbing compound. Yes, after claying you are supposed to wash the vehicle. What you are citing does not say that every time you clay your car it strips off all the polish. Space age polymer hype? We've been in space since Sputnik. Lot of good legitimate innovations have occured since then. Last edited by hiker chick; 11-30-2005 at 07:56 PM. |
| Thread Tools | |
| Display Modes | |
