"D" for drive is flashing - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 03-12-2006, 10:31 AM   #1
Honda Box
EOC Rank: Hydrogen
2003 4WD EX
Shoreline Mist Metallic (SMM)
Well, my father just called me and asked me if i knew what would cause his E shift harshly into reverse and drive from park. He said the "D" on the dash is always flashing now no matter if it's in drive or park or any other gear. I have no idea what would cause this but teh manual says there may be a tranny problem. Has anyone heard anything about this or any tranny problems that may cause this?
Thanks for any help
steve
oh yea, like father like son, we both have elements :)
__________________
I LOVE MY HONDAS
03 SMM Element
92 B20 Civic Si
Honda Box is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-12-2006, 07:47 PM   #2
Glynis
EOC Rank: Helium
2006 4WD EX-P AT
Kiwi Metallic (KM)
Send a message via AIM to Glynis
Re: "D" for drive is flashing
I'd be willing to say that your father should NOT drive it, but should get it to a repair place and get it looked at immediately. It sounds like a definite transmission problem to me.
One of the laws of car repair physics states that a transmission will fail completely at the worst possible moment, such as on an uphill exit ramp in a busy part of town with emergency lane and no room to pull over.
__________________
2006 Kiwi EX-P AWD AT - "Isotope"
Home Depot grill guard, memory foam steering wheel cover, EOC chrome decal, too-small cargo tray, biohazard floor mats, lime green "beverage carrier" for keeping the milk and soda from sliding around...
Glynis is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 08:36 PM   #3
MikeQBF
Moderatorium
2008 4WD EX-P 6MT
Galaxy Gray Metallic (GG)
MikeQBF's Avatar
The flashing is the transmission computer's blinking an error code in attempt to tell you what's wrong with it. Whatever it is has to be pretty bad to result in a code.
This is very unlikely to resolve itself, and it is undriveable as long as it's flashing the code. Have him call for a tow.
MikeQBF is offline   Reply With Quote Quick reply to this message
Old 03-13-2006, 08:41 AM   #4
Honda Box
EOC Rank: Hydrogen
2003 4WD EX
Thanks for all the replys guys.
It turns out that a wire leading to a sensor right behind the battery mounted to the tranny was chewed through by a mouse or something. I'm glad he found that before calling for a tow taking it to the dealer would have been a big headache.
thanks again
steve
__________________
I LOVE MY HONDAS
03 SMM Element
92 B20 Civic Si
Old 03-13-2006, 09:32 AM   #5
MikeQBF
Moderatorium
2008 4WD EX-P 6MT
MikeQBF's Avatar
Good diagnosis work!
I'll bet you the error code being flashed was "XYZ sensor not responding" or something like that, so if you had the $70 service book for the codes you would have looked there sooner or later... glad it was sooner!
Old 03-31-2006, 09:30 PM   #6
element au
EOC Rank: Helium
2003 2WD DX AT
Satin Silver Metallic (SSM)
element au's Avatar
A flashing "D" means that the computer, known as the PCM is saying there is a problem with the transaxle. Now, that said, and as noted earlier in the post, a loose wire can cause this problem. In the Element, there are quite a few bus oriented wiring harnesses or wires that connect to multiple sensors and then make their way to the PCM. They send digital signals that the PCM interprets and acts on. Makes sense that a loose wire could cause the problem.
The dealer will plug in and run a test, record the error code, clear it, drive the car, and then check for error codes again. If they can't replicate the problem, they will inspect the electrical harness connections associated the the transmission.
BTW: The connectors are self-cleaning and, with the battery disconnected, you can pull them off and connect them again. Although, if its a new car, the dealer should do it for you.
TB
element au is offline   Reply With Quote Quick reply to this message
Old 03-31-2006, 11:23 PM   #7
tango
EOC Rank: Carbon
2006 2WD EX-P AT
Tangerine Metallic (TM)
tango's Avatar
I had an SUV (not an E) that did this in Nov - engine light, transmission light, lurching, running in "gimp mode" - the whole thing - it was just a bad sensor. Was in & out of the shop in 4 hours. No biggie. Didn't get it towed - in fact drove it 200 mileas AFTER the warning lights came on - had no choice, was that far from home, at night, alone. Didn't hurt the car at all, was just a pain to drive it like that. Prob a defective sensor since the vehicle is brand new --- or something shook loose in transport. Don't think its anything more problematic than that.
__________________
tango is offline   Reply With Quote Quick reply to this message
Old 02-17-2007, 07:01 PM   #8
supadupamikey
EOC Rank: Hydrogen
2003 2WD EX AT
D for Drive flashing, Check Engine light - Code P0980 Open Shift Solenoid Circuit C
Had my 2003 Element EX 2WD Automatic (38k) for about 3 weeks now. Was driving home from work yesterday when I felt the Element 'jerk' when shifting, and immediately my Engine light came on and the D for Drive started flashing. I was a block from home so I parked it and went about my day.
This afternoon, I took the Element to Autozone to have them pull the code(s). It came back with P0980 - Shift Solenoid C. I've looked this up online and its also worded as "Shift Solenoid C High" and "Open in Shift Solenoid Circuit C".
On the drive to/from Autozone, it starts off in 1st gear like normal but when accelerating up to speed, it doesn't shift into 2nd gear unless i completely let off the gas and then it shifts/jerks into 2nd gear. I dont think it shifted into 3rd gear at all. I only got up to around 45MPH and the rpms were a little over 3k.
So I get back home and start peeking around wondering if a sensor came unplugged or a wire is cut/torn/etc. I removed the battery and unplugged and replugged like 7-8 sensors that were around the transmission. The sensors/wiring all 'looked' fine to me.
Anyone have any ideas? An "open" means that theres a break in the electrical connections somewhere. However, where do I start looking? What is Shift Solenoid Circuit C? and where is it?
thanks!
-Mike
supadupamikey is offline   Reply With Quote Quick reply to this message
Old 02-17-2007, 07:31 PM   #9
Dom.five
EOC Rank: Nitrogen
2006 4WD EXS AT
Atomic Blue Metallic (ABM)
Dom.five's Avatar
It's the Blu/Yel wire coming out of the Powertrain control module at the c7 position marked LSC( the PCM ).
There is a specific set of conditions that the test MUST be run under.
The connector is the center one on the PCM. There are 2 connectors on each side of it. The wire you want is the one on the left end top row as it plugs into the PCM. You will see the Blue yellow wire. There is only one other Blu/Yel wire going to the PCM. The other one is on an End ( outside edge ) connector, and not the one you want.
The C solenoid valve controls the pressure ports leading to the second and third clutches.
It may be a bad lead or a bad solenoid, Or God forbid, a bad PCM!
There is a test procedure that's 2 pages long that will lead to the source of the trouble.
I hope this helps
Dom
__________________
Home made Grill guard, Blacked out lower front bumper trim,and Grill, Undercoating, Vent-Visors, Bug deflector, EOC Sticker, Honda Floor mats, Honda Wheel locks, Eurotech Engineering Fog lights, Dual tone Horn from a junk Caddie, Oh and the 2.98$ walfart windshield tint strip, that's got to go when EOC puts one out. U-haul hitch with factory Honda harness. Garmin GPSmap276C True, I've been IRV'ed , : Misfits waNNAbe's
We love our E's !! ___ We are A 2 E family !
Dom.five is offline   Reply With Quote Quick reply to this message
Old 02-18-2007, 10:48 AM   #10
MikeQBF
Moderatorium
2008 4WD EX-P 6MT
MikeQBF's Avatar
Quote:
Originally Posted by supadupamikey
Just ordered the shop manuals. Was hoping to wait a couple more weeks until I finish rebuilding the motor in my Integra gsr and sell it, but this can't exactly wait.
i hate cars. ??:
Actually, it sounds more like cars hate you. :D
For something like this where you have an "open circuit" error, I would be going to every connector in the likely circuit and "freshening" the contacts by unplugging/replugging each one. ECU and transmission connectors would be at the top of my hitlist.
That's a trick from my (all-too-ancient) experience with not only cars, but big computers, too. Merely the act of removing and reinstalling a board would frequently cure everything from a solid no-op condition to a rare flakiness, all attributable to a dirty contact or something similar.
Sponsored Links
Advertisement
Reply
Tags
blinking , drive light , flashing d , gear , instrument cluster , shifting , shudder , transmission
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The Honda security system flashing led Kennewick_Man Mobile Electronics 4 01-19-2006 02:37 PM
Got my Flashing Brake Light and DRL Modules eKennedy Do-It-Yourself / Mods 2 01-19-2004 12:19 AM
