Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Mobile Electronics
Notices
ElementOwnersClub.com is the premier Honda Element forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Closed Thread
Thread Tools Display Modes
Old 07-15-2003, 12:06 AM   #1
eMass
EOC Rank: Oxygen
eMass's Avatar
This is a work in progress but I believe it is accurate. If I've mis-labeled something or left something out - please let me know. This diagram is a work in progress not a bible. :D
The main goal of this integration diagram is to show how an aftermarket head unit with RCA pre-outs, non fading subwoofer control, and an aux source can be fully integrated with the Element EX factory amplifier, subwoofer, speakers, and AUX jack without any special integration equipment such as line level converters, etc. All you need is some male RCA jacks and some patience.
Lastly, please be aware that the image below is considered intellectual property and should not be downloaded for the purposes of posting elsewhere or linked to elsewhere on the Internet. Thanks for your cooperation. :D
eMass is offline
Sponsored Links
Advertisement
Old 07-15-2003, 07:36 PM   #2
eMass
EOC Rank: Oxygen
eMass's Avatar
Just for reference - the following diagram will give you an idea of what the wiring on the back of an aftermarket head unit might look like. If the head unit below had an AUX source and non fading subwoofer control you'd see 2 additional pairs of rca pre outs...
eMass is offline
Old 08-10-2003, 01:36 AM   #3
Sheniferous
Moderateur Extraordinaire
2003 4WD EX AT
Shoreline Mist Metallic (SMM)
Sheniferous's Avatar
eMass you rock.
Thanks for this post, it'll make things a LOT easier!
__________________
Honda Accessories: Roof Rack, Cargo Cover, Table Legs, Cabana Tent & Poles, Side Steps
Aftermarket & Homemade Accessories: Billet aluminum grille, Silverstar headlights, Cyberwhite Fog and Driving Lights, Hardwired 400W power inverter, Extra 12v socket, Homemade nylon privacy curtain, Rear sunroof sunscreen,
Tires: Yokohama Geolandar H/T-S 225/70/R16
SEARCH, RTFM, POST.
Sheniferous is offline
Old 08-21-2003, 07:33 PM   #4
Eward
EOC Rank: Hydrogen
Thanks for the diagrams.
I have 2 questions.
1) I am using the metra 70-1721 harness adapter, but it DOES NOT have the Amplifier Turn on wire. Is the amp auto powered when there is a signal? There are only 14 wires coming, not 15 like in the diagram.
2) I have a left and right subwoofer RCA input on my head unit. How I connect it to the mono-subwoofer inputs? (just the left?)
edit: one more question
3) Does the PAC RCA to Line Level Adapter go in between the speaker +/- and the RCA plugs on the left side of the diagram?
Eward is offline
Old 08-25-2003, 08:03 AM   #5
mike1007
EOC Rank: Hydrogen
1. The Power Antenna lead is also the Amplifier Turn On. I had the same problem where the speakers came on only when I was in Tuner mode. I then connected the Element's Power Antenna to the Amplifier Turn On of my new head unit.
2. You mean left and right subwoofer OUTPUT right? I just connected mine to the left and seems to be working fine.
System:
Clarion ProAudio VRX935VD DVD/MP3 Receiver/7" LCD Monitor (sound processor under driver's seat)
Infinity Kappa 6.1 components (rear)
Rockford Fosgate Punch 801X 4 Channel Amplifier (under driver's side rear seat)
Existing Element's Front speakers and subwoofer.
Mike
mike1007 is offline
Old 11-06-2003, 12:42 PM   #6
brendan
EOC Rank: Iron
brendan's Avatar
Send a message via AIM to brendan
eMass,
Do you happen to know if the OEM unit has a mute-wire?
-brendan
brendan is offline
Old 11-13-2003, 05:16 PM   #7
brendan
EOC Rank: Iron
brendan's Avatar
emass -
Three areas of concern:
1. The picture of the Metra 70-1721 on your diagram doesn't match mine. Is that the same part, or not?
Other than it being black (mine's white), the harness having an outer positive locking assembly (mine doesn't), it seems like the business end is exactly the same, but the wiring indicates it was *mirror image* flipped (like someone imaged a negative that was layed down on the wrong side).
Also, mine seems to be missing the amplifier turn on wire, all the rest are there. Is that needed?
2. The subwoofer (red/blue, red/white) cables: are those on the same harness, or elsewhere?
3. Related: on element-j's headunit page (http://www.re-vision.com/element-j/head_unit.html), the blue plug is what we connect the 70-1721 into, yes? The white/black plug is, I assume, the aux socket plug, yes? But what's the green plug for??? Wait a sec, it matches the color of the socket at the amp. ugh, i think my assumptions are all wrong. :(
thanks for any help you can give...
-brendan
__________________
2003 NBP Auto AWD EXS
Empeg MkIIa (RioCar)/Pioneer DEH-750MP/XM Roady [KD4YJS]
Parrot CK3000 bluetooth speakerphone w/ SE T610 / TomTom Go GPS
Valley Hitch/Softride 4-bike rack/Weatherflectors/Cloud Riders/Lots of dirt
brendan is offline
Old 11-14-2003, 10:09 AM   #8
eMass
EOC Rank: Oxygen
eMass's Avatar
The pictures are for illustration only and do not represent the actual harnesses. The wiring diagram colors should match the diagram although it's always safer to match the functions - not the colors.
I believe he amplifier turn on wire for the Element is actually the antenna lead. If there's nothing to conenct the amp turn on to then don't.
The subwoofer cables should be on the same harness.
The harness plugs are all keyed so that you can't plug something else into it. It will all be much clearer to you when you take things apart and look at them although the guide above is no substitute for professional assistance from your local car stereo shop! :)
eMass is offline
Old 11-14-2003, 10:35 AM   #9
brendan
EOC Rank: Iron
brendan's Avatar
Quote:
Ok, good.
Ok, I'll keep that in mind, and be prepared to do some last minute rewiring for that at the car.
Oh. Huh. The 70-1721 I have doesn't have enough wires to carry a separate subwoofer channel. Great.
Ok, no guarantee, I understand. :)
One last question:
What's the green plug going into the stock EX headunit shown on Element-J's site? The larger white one is what I plug the 70-1721 into. I assumed the smaller white was the aux-in connector. That still leaves a bunch of leads on the green connector un-accounted for...
thanks again, emass,
-brendan
__________________
brendan is offline
Old 12-08-2003, 09:52 PM   #10
BlackBurn
EOC Rank: Hydrogen
2004 4WD EX AT
BlackBurn's Avatar
Send a message via MSN to BlackBurn
u got a stock amp wiring diagram?
__________________
2003 Honda Element: Shoreline Mist: Automatic
Alpine 6.5s (soon to be installed)
Pioneer deh-p6600h deck
BlackBurn is offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
