DIY Honda Pilot Leather Steering Wheel Swap Out Guide - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Do-It-Yourself / Mods
Notices
Reply
Thread Tools Display Modes
Old 07-17-2003, 01:31 PM   #1
eMass
EOC Rank: Oxygen
eMass's Avatar
Here’s a complete DIY guide for swapping out the stock Element steering wheel for a leather one from a Honda Pilot.
I found my Pilot steering wheel on eBay. I looked at various parts sources on the Internet and concluded that eBay is much cheaper. I got my wheel for $35 plus shipping but since you could pay $150 or more through an Internet dealer anything under $75 seems like a pretty good deal to me.
This is a simple job if you have the right tools and have a modest amount mechanical ability. Do not attempt this mod if you do not have the proper tools. You will need the following…
  • 1/4” drive ratchet and extension
    3/8” drive ratchet and extension
    1/4” drive Torx T30 socket bit (for 2 airbag bolts)
    1/4” drive Torx T40 socket bit (for 4 horn plate bolts)
    3/8” drive 14mm socket (for steering wheel bolt)
    Philips head screwdriver (for various trim pieces)
Once you have the proper tools, make sure you’ll be working in a well lit area. The whole process takes about 30 minutes if you take your time and follow these instructions precisely. Let’s begin.
Step 1: Turn off the horn!
When you remove the two airbag bolts the horn will sound unless you do something about it first. All you have to do is open the hood, find the fuse box on the driver’s side near the battery and squeeze the four tabs together to take the lid off. Once the lid is off, find the 15 amp fuse for the horn and remove it. There is a fuse puller right inside the box for this purpose. See the diagram below…
Step 2: Remove the airbag bolts
Get out your 1/4” drive ratchet and extension and snap on the Torx T30 bit. Take out one bolt on each side of the airbag. Extract the bolts from the holes and put them in a safe place. See the picture below…
Step 3: Remove the airbag
In order to remove the airbag once the bolts are removed carefully pull it towards you until you can reach behind the airbag and disconnect the large yellow wire clip. Set the airbag aside. See the picture below…
Step 4: Take a good look!
Make a mental note, or a drawing, or use the picture below to remember how things are laid out at this point. This is important since you’ll need to put things back exactly this way when done.
Step 5: Prepare to remove the steering wheel
Make sure the wheel is straight. Disconnect the black wire clip on the left and the green wire clip on the right. Get out your 3/8” drive ratchet and extension and snap on the 14mm socket. Remove the center bolt. Put the bolt in a safe place. See the picture below…
Step 6: Remove the steering wheel
Again, be sure wheel is straight. Gently but firmly pull the wheel towards you with a left-to-right rocking motion. As you pull the wheel off be careful not to catch the wire clips on the steering wheel as they pass through the center hole! After removal, let the wires dangle freely. IMPORTANT: Do not touch or spin the white airbag plate on the column! More info on this issue here.
eMass is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-17-2003, 01:37 PM   #2
eMass
EOC Rank: Oxygen
eMass's Avatar
...continued from previous post.
Step 7: Begin swapping over steering wheel components
1. Remove the two plastic side brackets on the front of the steering wheel using your Philips head screw driver. There are two screws for each piece. Set them aside in a safe place.
2. Remove the four gold bolts on the horn plate by using your 1/4” drive ratchet and extension with a Torx T40 bit. Lift plate off with bolts intact being careful to also take the springs with it.
3. Remove the large plastic back trim cover from the steering wheel by removing four Philips head screws. Transfer the back trim cover over to the new steering wheel and secure all four screws. Do not over tighten.
4. Remove the two Philips head screws in the counter weight and transfer to the new steering wheel.
5. Transfer springs, and horn plate with bolts over to the new steering wheel and secure bolts tightly but do not over tighten.
6. Transfer the two plastic side brackets over to the new steering wheel, securing them with 4 Philips head screws. Do not over tighten.
Before:
After:
Step 8: Install the new steering wheel
1. Route the three wires through the rectangular opening underneath the steering wheel bolt hole.
2. Align wheel and white airbag plate so that they are straight and centered with two side posts and push the wheel firmly on to the post. Check for straightness before proceeding. Repeat procedure if necessary if wheel is off center.
3. Replace and secure 14mm steering wheel center bolt.
4. Connect and route all wires exactly as shown in the picture on step 4.
5. Connect airbag wire clip and reinstall airbag with the two Torx T30 bolts from step 2.
6. Reinstall horn fuse as shown in step 1. Test horn. Reinstall fuse puller and secure fuse box lid. Close hood.
Almost done…
Installation is complete!
Here is a picture of the finished project…
Old 07-17-2003, 01:47 PM   #3
Ramy
EOC Rank: Hydrogen
2003 4WD EXS AT
Shoreline Mist Metallic (SMM)
Well documented!
Ramy is offline   Reply With Quote Quick reply to this message
Old 07-17-2003, 05:27 PM   #4
marky
EOC Rank: Oxygen
2003 4WD EXS
Nighthawk Black Pearl (NBP)
marky's Avatar
Well done! I would only add disconnecting the negative battery cable before doing anything. Sometimes disconnecting the airbag sets an error in the airbage computer, and you'll need a trip to the dealer to reset it.
marky is offline   Reply With Quote Quick reply to this message
Old 07-18-2003, 08:37 AM   #5
eMass
EOC Rank: Oxygen
eMass's Avatar
Taking the negative cable off in place of removing the horn fuse is not a bad idea. As far as the warning light coming on though, I believe this will only happen if you switch the ignition on while the airbag is removed. The internal computer always does a check for the airbag at startup and if it's not there the computer flags it.
Old 07-18-2003, 11:44 AM   #6
Slowhand
EOC Rank: Oxygen
Two questions:
How do you like the new wheel?
What are the Pilot people swapping into their vehicles that is making their steering wheels pop up for sale?
(BTW, great tutorial - you are a great asset to the club)
Slowhand is offline   Reply With Quote Quick reply to this message
Old 07-18-2003, 12:36 PM   #7
Bob Crosley
EOC Rank: Hydrogen
Send a message via MSN to Bob Crosley
[quote:89d7cbeb21="Slowhand"]What are the Pilot people swapping into their vehicles that is making their steering wheels pop up for sale?[/quote:89d7cbeb21]
Strangely enough, Element steering wheels. ;)
__________________
2003 Nighthawk Black Pearl AWD EX
Bob Crosley is offline   Reply With Quote Quick reply to this message
Old 07-18-2003, 01:18 PM   #8
eMass
EOC Rank: Oxygen
eMass's Avatar
Quote:
Originally Posted by Slowhand
Two questions:
On the feel: I love it. It's buttery soft and it has the right thickness.
On the wheel availability - ya know, I have no idea how people are getting their hands on these at such a price - mine was new in the honda parts box so it wasn't a swap-out. Like I've said before, you can spend $150 or better on this from any parts dealer. I can't imagine how much the actual dealer cost is but I can't imagine its less than what I paid!?!
I feel lucky to have gotten my hands on this (no pun intended) for the price that I did. It makes driving my E just a little more enjoyable.
And BTW, thank you for the compliment - remember, the best Element content is right here at elementownersclub.com!
Old 07-18-2003, 04:34 PM   #9
marky
EOC Rank: Oxygen
2003 4WD EXS
marky's Avatar
My dealer told me that the leather wheels are the swap outs from the folks that get the wood wheel. Maybe Honda ships the Pilots with the wheel not installed, as the one I got off Ebay was in a Honda box as well.
Old 07-18-2003, 09:06 PM   #10
eMass
EOC Rank: Oxygen
eMass's Avatar
Oh right, come to think of it there IS a wood steering wheel for the Pilot too. They must be the leftovers from that option.
The box is probably from the wood steering wheel that gets shipped to the dealer.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
FS: Honda Pilot leather steering wheel Joemama422 Trading Post 28 04-29-2008 05:25 PM
Honda Pilot Leather Steering Wheel Swap Juicebox Do-It-Yourself / Mods 5 03-26-2005 08:48 PM
Honda Pilot Leather Steering Wheel For Sale blackdog1 Trading Post 2 02-13-2005 02:22 PM
DIY Honda Pilot Leather Steering Wheel Swap Out Guide eMass 'E'ccessories 0 07-17-2003 02:34 PM
