| Register | FAQ / How To's | Members List | Honda Dealers | Honda Club Store | EOC Calendar | Search | Today's Posts | Mark Forums Read |
| Notices |
Thread Tools | Display Modes |
#1 |
EOC Rank: Hydrogen
2003
2WD EX AT
Towing capacity
hey guys I have a Baja bug that I would like to tow with the e it would be on all 4 tires and just have a tow bar attatched the tounge weight is very minimal. do you think it will be ok? the bug weighs around a 1000 pounds
| Sponsored Links | |
Advertisement |
#2 |
EOC Rank: Oxygen
Yes - it should be fine.
If you like a challenge - use a chain instead of a tow bar. :wink: |
#3 |
EOC Rank: Hydrogen
2003
2WD EX AT
na thats ok I think I will stick with the tow bar. this way I can throw my paddle tires in the bug and all of our camping gear in the cargo pod and have plenty of room to carry all the stuff we need for romping around in the sand all weekend.
#4 |
EOC Rank: Hydrogen
i have a bass boat thats around 2000 lbs. can the element handle that?
#5 |
EOC Staff
2003
4WD EX
Eternal Blue Pearl (EBP) |
The Element is only rated to tow 1500lbs. I tow a pop up camper that runs about 1300lbs comfortable but feel that 2000 is way too much. It may 2000lbs. from the factory but by the time you put your stuff in it and run it on the water there will be a lot more weight to pull up a boat ramp!
__________________
2003 4wd EX Eternal Blue Pearl Honda Element! 2003 Flagstaff 176Ltd. 2004 Seadoo GTX 4TEC Supercharged PROUD Member of the EOC MISFITS established 14, July 2005. |
#6 |
Moderatorium
2003
4WD EXS 6MT
Shoreline Mist Metallic (SMM) Join Date: Sep 2003
No. Not safely.
I would suggest considering the Honda Pilot.
__________________
http://www.albinoblacksheep.com/flash/posting.php |
#7 |
EOC Rank: Helium
I have a Boston Whaler Jet boat approx 1600 lb., not a problem for my E even going up a pretty steep grade in the mountains of NH... our camp is 55 miles one way, no problems, you do notice that you are pulling though... you would want to make sure you have a 2" hitch, not the honda option and make sure you are not over 2000 lbs. as one post suggests, often when you add fuel, supplies and other things you get closer to 2300 lb. which would likely push the E over the limit.
__________________
2003 Element EX AWD AUTO Shoreline Mist INTERIOR: Black/Gray, 10 Disc, Silver Interior Trim Kits, Carpeted Floor Mats, Bungies EXTERIOR: Hitch, Side Steps, Rear Deflector, Mud Flaps, Rear Bumper Trim, Chrome Exhaust Tip, Roof Rack |
#8 |
EOC Rank: Hydrogen
The perfect vehicle for me! A good interior for two dogs, the utility I liked in my Nissan pick-up, and the gas mileage I want (short of a turbo-diesel).
But how much can I tow? I've got two boats. I know the 16' sail boat will be no problem, but how 'bout the 19' center console (??3000 lbs??)? My prior pickup, with a 2.4L 4 cylinder could pull the motorboat. Even my current Subaru 'can' do it, but don't tell anybody (clearly I shouldn't be using the 'ru to pull such a heavy load). Does anybody have a stat for me? or just a good suggestion?? Thanks |
#9 |
Moderatorium
2003
4WD EXS 6MT
1500 lbs. max, 150 lbs. tongue weight max. You need to find something else for your 19-footer.
__________________
#10 |
EOC Rank: Oxygen
2003
4WD EX
Galapagos Green Metallic (GGM) Join Date: Aug 2003
Rated at 1500. I would imagine it can do more, but wouldn't push it too far.
__________________
C-YA: 2003 GGM EX AWD 5-speed, 42,700 flawless miles averaging 22+ mpg, treat your next owner well. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| more towing capacity | dj fontine | Dear Honda: (Feedback Forum) | 0 | 11-08-2009 07:52 PM |
| Towing Capacity - truth hurts | Igneouss | Trailers, Campers and Teardrops… oh my! | 30 | 10-24-2009 06:15 AM |
| '09 Towing Capacity | TSac | Racks, Hitches & Towing | 12 | 10-13-2009 12:11 AM |
| Towing Capacity: Understated In U.S.? | BigFoot | Trailers, Campers and Teardrops… oh my! | 74 | 11-20-2008 10:01 AM |
| Towing Capacity | fliggie | Under The Hood / Performance | 2 | 11-29-2005 08:44 AM |
