| Register | FAQ / How To's | Members List | Honda Dealers | Honda Club Store | EOC Calendar | Search | Today's Posts | Mark Forums Read |
| Notices |
Thread Tools | Display Modes |
#1 |
EOC Rank: Oxygen
2003
4WD EX
Nighthawk Black Pearl (NBP) Join Date: Sep 2005
radio, hvac color change
Alright, need some help.
I don't have the energy nor time to go through each of the pages on this thread, not to mention those threads linked through this thread. Basically the two of my A/C controls lights went out and I need to replace them. What bulbs will I need? Can I get them at an Advanced Auto Parts / Pep Boys / Auto Zone / etc.? Also I was thinking about maybe adding a different color to them, can I get the very same bulbs at an auto parts supplier? Need some help |
| Sponsored Links | |
Advertisement |
#2 |
Mod-erator
2006
2WD EX-P MT
Tangerine Metallic (TM) Join Date: Apr 2006
The best place to get those bulbs is at your local Honda dealer....dont' worry there not too expensive :D
#3 |
EOC Rank: Carbon
2006
4WD EX-P MT
Nighthawk Black Pearl (NBP) |
You could purchase the old bulbs and then color them with some glass stainer or even try using a sharpie marker (as it was suggested earlier). For vibrant color, the best way is to with an LED conversion but to do this with the HVAC controls is much more involved and time consuming than doing the gauge cluster. The bulbs you need for the HVAC controls are placed in a 'custom' plastic housing which you can get from Honda. That's the easiest way anyway. I mean if you really wanted you could replace the bulbs yourself by pulling them out and inserting new bulbs, but honestly it's probably not worth it unless you intend to do the LED conversion. To change the bulbs is fairly easy. Basically you just have to pop off the center console, disconnect the plugs that attach to the HVAC controls and the hazard switch and with a flathead screwdriver unlock the twist bases which you can see on the back of the HVAC controls. They will fall right out. Pop the new ones in, twist lock them and you should be set to go.
__________________
"The Black Sheep" 2006 EX-P "SC-X" Project [OEM Accessories : SC Part Swaps : Performance & Handling : 1800w Audio/Video System : DIY Modifications] Thinking about HID's? Consider an SC Front End Conversion for HID-required projector headlights. |
#4 |
EOC Rank: Hydrogen
2004
4WD EX AT
Fiji Blue Pearl (FBP) Join Date: Aug 2007
Hi
Is there a "definitive" guide for changing the lights on clusters and HVAC? Or is this thread it? I had a few other questions: How Many LED's do I need for the Cluster? Are they all supposed to be #74 size? What is the easiest way to replace the lights in the HVAC with LEDs? Thanks, |
#5 | |||
EOC Rank: Oxygen
2003
4WD EX AT
Satin Silver Metallic (SSM) |
Quote:
Quote:
Quote:
You're Welcome
__________________
Named: Echo 3 Mods: Hyper Grounding Kit, Infinity 6002si speakers all around, Infinity REF 1011T Tweeters, Hyper White Back up lights and license plate lights, custom exhaust with Magnaflow, AEM Cold Air Intake, DIY red instrument panel bulbs, retrofitted HID with bixenon projectors, Pioneer AVIC-D2. Echo 3 no longer belongs to me. Mom's driving it now. Now I drive the Si sedan. |
#6 |
EOC Rank: Hydrogen
2004
4WD EX AT
thanks very much for the great info!
I think I found the link you were talking about: http://www.cardomain.com/ride/807962/1 I also wanted to know if the lights for the Odometer are #74's and if there is any special instructions for that change. |
#7 | |
EOC Rank: Carbon
2006
4WD EX-P MT
Nerdbox, here's a copy of a PM I sent to another member a few weeks ago concerning the instrument cluster.
Quote:
As for the HVAC controls: it is no where near as easy and I found it to be fairly complicated but maybe you'll have better luck with this advice: 1. You need two kinds of LED bulbs: 5mm and 3mm. The 5mm are for the dial faces while the 3mm are for the buttons. You are also looking for the following characteristics for both:
You may want to invest in several of these. I destroyed about 10 through experimenting and trying to get the finished product. 2. Remove the center dash trim piece that has the HVAC controls attached. Disconnect the plugs for the unit so you can take the piece away from the dash. Remove the unit by removing 4 screws on the back end (key for later on when you're testing it out). On the back side of the HVAC unit you will see the same thing you saw with the instrument cluster - twist lock posts. 1/2 turn and it should come out... sometimes with a little upside down shaking. 3. Analyze the things which came out and take note of how the metal wraps around the bottom of the post. You will have to do this later on since this is how they make contact with the circuit board. Straighten the metal and pull the bulb straight out with the leads. The general idea is to install the LED's the same way the bulbs were oriented. Make sure when you install the LED's that they are pointing straight. If you purchased LED's with integrated resistors and solid metal leads which are long enough to wrap around this will be fairly easy. In the event that they will not fit (too long with the LED in the post) simply cut the post down bit by bit until it fits. You can also do this if your leads are not long enough. They just need to be able to reach the top of the base to make contact. Now: unlike the old bulbs, LED's have a + and a - end so simply placing the newly modified post back into the HVAC unit does not mean it will work right away. Place it in, plug in the controls and try it out. If it does not light up, then try rotating the post 180° and try it again. It should turn on either the first or second time. Now you know why you separated it from the dash piece. In the event you have external resistors, you will need to do the following:
Good luck. PM me if you need help. Oh, yeah - "Hyperwhite" is white with a tint of blue... almost like a light blue BTW.
__________________
"The Black Sheep" 2006 EX-P "SC-X" Project [OEM Accessories : SC Part Swaps : Performance & Handling : 1800w Audio/Video System : DIY Modifications] Thinking about HID's? Consider an SC Front End Conversion for HID-required projector headlights. Last edited by wastedonanime; 08-31-2007 at 12:32 AM. |
#8 | |
EOC Rank: Oxygen
2003
4WD EX AT
Quote:
Nope same as the other bulbs in the cluster.
__________________
#9 |
EOC Rank: Oxygen
2003
4WD EX AT
Sunset Orange Pearl (SOP) |
for the HVAC controls.. what are everyones thoughts on these?
![]() go to http://autolumination.com/74.htm its about half way down the page.. they look like type A's or B's to me. just guessing though
__________________
#10 |
EOC Rank: Oxygen
2003
4WD EX AT
i decided to try the stained glass paint idea. seeing some people say they werent happy with how it turned out i tried to work with it in a way to improve on just painting the bulbs. so i actually did the inside of all* the buttons and knobs as well as the bulbs themselvs
*the only bulb i did not paint was the center hvac knob bulb so i could retain the blue and red color on the knob itself heres the end result.. i still have a little more to do. and i have to replace one of the hvac bulbs.. i broke it, haha ![]() ![]()
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| MTP's radio control / steering wheel mod | MTP | Do-It-Yourself / Mods | 31 | 01-02-2010 02:33 PM |
| Info about 05' EX Radio installed in 03-04' | moto-scoot | Mobile Electronics | 2 | 11-16-2008 03:59 AM |
| HD Radio, XM, Antenna | Texaco66 | Mobile Electronics | 3 | 05-08-2007 06:22 PM |
| sound quality - CD, MP3 & Satellite Radio | outpost4 | Mobile Electronics | 29 | 10-16-2006 06:17 AM |
| Strange Radio Behavior | myFifth | Problems & Issues | 2 | 06-24-2005 03:19 AM |
