Thanks for the reminder of this mod, nanook. The morning I left for the EOC meet, I drilled out *two* holes in the center console. One on the passenger side of the front cupholder (like yours) and an additional one on the driver side of the front cup holder. A 1&1/8" drill-bit was what I needed (for the marine sockets, see below).
Unfortunately, for the first hole, I "measured once and drilled twice", that is, I screwed it up by using a 1" bit. DOH.
Needless to say, drilling a 1.125" hole into the spot that a 1" hole already exists was not very fun.
Then I installed two of the following sockets, cleverly covering up the butchering job on the first holel:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=265-274
They're the generic versions of the Marinco boating sockets (which area also available from partsexpres). The sockets accept standard 12V DC plugs, but if you use Marinco plugs, they interlock and are water-resistant as well. That seemed appropriate for low-lying 12V DC sockets in the hose^H^H^H^H sponge-out-able E.
Anyway, today I finally finished the mod...
Thanks for the tip on the coat hanger. I used the unravelled coat hanger's twisty part to keep the wire in place. Still, I had to get creative...I had to pull up on the flooring between the center console and the middle column to give the coat hanger enough play to pull through. Three or more hands would have made this part much easier. What a pain in the tukus.
Since I was running *two* sets of wire, I chose to use the removal of the coat hanger to pull the second wire back through. I'm one clever monkey!
I routed the wire behind the wiring looms on the center column making it nearly impossible for the wires to come loose in the way of access to the gas or brake pedals.
Unfortunately, I used 10 gauge wire, thinking "hey, you never know when you might end up needing to rewire these for 20 amps. This ended up being amusing, since most of my connecting hardware, including the Littlefuse mini add-a-circuit wire endings, have connections for 14-16 gauge wire. Some snipping, part modifying and parts scrounging and I made due. Perhaps I should have stuck with 12-14 gauge wire...
For power, I used fuse locations 3 (DRL control unit) and 18 (front socket) to attach the add-a-circuits. The end result is that the driver's side socket is *always* powered (via position 3), and the passenger side socket is powered when the key is turned in the ignition (via position 18...). I like that combo.
For grounding, I used a bolt below the middle console to ground both sockets.
Lastly: have you noticed that the console seems a bit too easy to mistakely pull loose when removing plugs from the sockets? Hrm
I was going to post pics, but...damn, the interior of my E is DIIIIIRTY.
-brendan
