anyone know how to read the SRS flash codes out? - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 01-15-2008, 04:14 PM   #1
rollertoaster
EOC Rank: Oxygen
2006 4WD EX AT
Alabaster Silver Metallic (ASM)
rollertoaster's Avatar
I Blew a fuse out being an idiot. Now my srs light it on. I'd like to be able to check the faults before I take it in to the dealer. Most likely it is something that I caused and I'd like to find out what it is before I have to pay for it.
__________________
formerly
GT3076r @14psi!!!
2010 wrx
Team Loweriders
rollertoaster is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-15-2008, 06:57 PM   #2
Honda Tech
EOC Rank: Helium
2003 4WD EX MT
Honda Tech's Avatar
Quote:
You have to ground the SCS terminal at the DLC to flash the codes. Since the DLC (Diagnostic Link Connector) is the connector for the scan tool, it is best NOT to go poking at the terminals with a jumper.
The best thing to do if you don't want to spend any money is just reset the SRS light - if the light goes off after the 6 second self-check, no worries.
Ramblerdan posted a link in post #43 of this thread.
http://www.elementownersclub.com/for...816#post530816
Don't worry about the warning about accidently triggering an air bag with this procedure if you are using a jumper wire (assuming that you ARE doing the procedure at the MESC connector as specified). The special tool makes it a lot easier to connect / disconnect / re-connect, but a jumper will work fine if you do it right. Do it wrong and you just do it right the next time.
__________________
"Success is 99% Failure"
Soichiro Honda
(not my site)
Honda Tech is offline   Reply With Quote Quick reply to this message
Old 01-15-2008, 08:00 PM   #3
rollertoaster
EOC Rank: Oxygen
2006 4WD EX AT
Wink
I already tried to clear the fault, it's currently present. I know about shorting stuff out in the dlc. I'm a bmw tech so I can't hook up with my test equipment. If you are'nt comfortable with posting flash code Diag on here for all to see, you can Pm me
__________________
formerly
GT3076r @14psi!!!
2010 wrx
Team Loweriders
Old 01-16-2008, 07:13 AM   #4
Honda Tech
EOC Rank: Helium
2003 4WD EX MT
Honda Tech's Avatar
Not a question of being uncomfortable posting it, just a question of taking the time to post a procedure in a manner that all could understand.
The DLC terminals are numbered according to SAE standard J1962
Terminal 9 is the SRS service short terminal. (BRN)
Terminal 4 is a ground.
__________________
Soichiro Honda
(not my site)
Old 01-16-2008, 08:23 AM   #5
rollertoaster
EOC Rank: Oxygen
2006 4WD EX AT
awsome thanks alot. one more question for now. Do i keep it grounded or just for a specified amount of time?
__________________
formerly
GT3076r @14psi!!!
2010 wrx
Team Loweriders
Old 01-16-2008, 08:25 AM   #6
Honda Tech
EOC Rank: Helium
2003 4WD EX MT
Honda Tech's Avatar
Short it, turn ignition 'ON', read the flash code(s), turn ignition 'off' then remove the short.
Note: it will not start flashing as soon as the ignition is turned 'ON', but will go off after 6 seconds, then flash the code(s).
__________________
Soichiro Honda
(not my site)
Old 01-16-2008, 08:34 AM   #7
spdrcr5
Site Sponsor
2003 4WD EXS AT
Sunset Orange Pearl (SOP)
spdrcr5's Avatar
Send a message via AIM to spdrcr5
Thanks JD, adding this to the FAQ/HowTo's.
spdrcr5 is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 04:09 PM   #8
rollertoaster
EOC Rank: Oxygen
2006 4WD EX AT
ok, this is what I've got.
15-1
I have 3 very fast blinks... pause... 5 slow binks... pause one faster blink then the light comes back on solid.
Would that correspond to 15main 1sub?
I don't have my ETM yet, would anyone be so kind as to tell me what fault that is?
__________________
formerly
GT3076r @14psi!!!
2010 wrx
Team Loweriders
Old 01-16-2008, 04:14 PM   #9
lizzurd
Moderator Eh?
2006 4WD EX-P AT
Neutron Blue Metallic (NBM)
lizzurd's Avatar
15-1
DTC 15-1
Faulty OPDS unit or OPDS unit is not initialized.
lizzurd is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 04:19 PM   #10
rollertoaster
EOC Rank: Oxygen
2006 4WD EX AT
ok, what is a opds? occupant detection sensor???
would that be driver or passenger?
Is there any way to initialize it without going to honda?
I'm sorry being a pain. If any of you have a BMW feel free to pester me back.
__________________
formerly
GT3076r @14psi!!!
2010 wrx
Team Loweriders
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OBD-II + Laptop + More Codes tooljedi Under The Hood / Performance 2 12-07-2011 10:19 AM
How to read OBD2 data? Rover Under The Hood / Performance 8 01-24-2006 04:14 PM
Side Step Installation - Read Before Attempting DigiNerd 'E'ccessories 13 10-26-2005 04:28 PM
Need Help Resetting Readiness Codes Windchill Mobile Electronics 3 07-10-2004 10:59 PM
