Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
ElementOwnersClub.com is the premier Honda Element forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Reply
Thread Tools Display Modes
Old 04-10-2008, 10:36 AM   #1
Fred111
EOC Rank: Hydrogen
My side window shattered this morning
I closed my passenger door this morning and the big long window on the passenger side shattered. The dealer said the only way that would or could have happened is if someone repeatedly slammed the door. No one has slammed the door once let alone repeatedly, in fact I closed the door rather gingerly this morning, imagine my surprise. I don’t know what I expected them to say. Anyway, what is that window called, quarter glass?
Fred111 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-10-2008, 11:04 AM   #2
Alchemy
EOC Rank: Helium
2003 4WD DX AT
Eternal Blue Pearl (EBP)
Alchemy's Avatar
Yikes! sad day my friend. Usually those things are really tough unless you hit it with a sharp point or it gets torqued somehow.
__________________
2003 4WD EBP DX AT, AR alloy wheels, rbr flr mts, rain grds, 8g usb & 3.5mm stereo, R. outlet always on, LED dome lights together, marker blinkers, Larkin E-hammock system, dirt, lots of dirt,
In process: fog lights always on, VHF rescue radio, H. Depot grill guard, running boards, R. hatch inside latch,
Future: rescue equipment organizer, lg center consel, keyless entry/remote start, utility rack/platform, overhead organizer, durabak, beautiful girlfriend mod
Alchemy is offline   Reply With Quote
Old 04-10-2008, 11:11 AM   #3
Snuffleupagus
EOC Rank: Carbon
2004 4WD EX AT
Satin Silver Metallic (SSM)
Snuffleupagus's Avatar
Quote:
I don't know what could have caused that. I hope you can get it fixed under warranty or something.
I think what the dealer said is a whole lot of BS. I personally would ask them to defend their claim.
When I first got my E, my passengers would constantly slam my passenger side doors, both front and back because they were not used to it. They still do at times. I myself have been guilty of forgetting to be real easy on the rear door on occasion. I have had no problems.
Good luck.
P.S. Where are you from, and what year and model is your E?
__________________
Beware the Dread Twirate Snuffleupagus Scourge of the Kiddie Pool!
Snuffleupagus is offline   Reply With Quote
Old 04-10-2008, 11:42 AM   #4
colin.sama
EOC Rank: Helium
2006 4WD EX-P AT
Tango Red Pearl (TRP)
colin.sama's Avatar
That sounds like a flaw. If your E is new it may have been twisted or something at the factory or in transport. The glass could have just been defective also. The problem will be proving it to get it covered under warranty (if it's still under warranty). Anyone could go out and smash a window then claim it just broke on it's own. I doubt you'll be able to prove it unless there is clearly a twist in the surrounding metal.
I suppose if when they try to replace the window it doesn't fit properly it would prove there is a flaw in the window frame.
Slamming your door, unless you're Chuck Norris, shouldn't shatter car windows.
Yes, it's called the quarter glass. (Majestic Honda Link for 2006 E)
__________________
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius — and a lot of courage — to move in the opposite direction.
- Albert Einstein
colin.sama is offline   Reply With Quote
Old 04-10-2008, 11:52 AM   #5
Earthride
EOC Rank: Hydrogen
2008 SC 2WD 5AT
Root Beer Metallic (RBM)
Earthride's Avatar
Send a message via AIM to Earthride
auto glass breakage
in my years, the only auto glass i've broken was as i was putting the rubber back on and touched the CORNER with a screw driver, the corners are very easly broken, then the whole glass will shatter.
i'd check the area around the corners on the frame where the glass window mounted . is there anything sharp or protruding into the area where the glass would seat in the rubber? was the rubber cracked or broken in any of the corners? glass can be touchy.
check on the frame of the body where the glass seats, if there's something there that the new glass, once installed rubs and it isn't cleaned up or fixed, it will break the new glass at some point. even just a big bump going down the road if it's not seated correctly.
hope this helps Tedd
__________________
Edited Mod's...
Bought a Honda Element, & Did sum stuff to it....
:cool: The most beautiful relationship can be destroyed because the truth wasn't told in the very beginning.... Earthride
Earthride is offline   Reply With Quote
Old 04-10-2008, 12:39 PM   #6
Twilightzero
EOC Rank: Magnesium
2007 4WD LX MT
Twilightzero's Avatar
That sux, but I agree sounds like the dealer's trying to roll you...
__________________
Twilightzero, International Man of Debauchery
You're all invited to Twi's Annual Bonfire Extravaganza - Oct 23, 2010!!
Join Cap'n Twirate's EOC Bucanneers!
Mods: ASA JS6 rims, Nokian WR-SUV tires, DIY roof rack, DIY Dog Platform, Curt Class III trailer hitch, Char Griller Super Pro Trailer Hitch Grill, Infinity 6022si Speakers, Shen's Side Marker Turn Signals, Leather shift boot, K&N filter, RoadRunner 34/78 Monster Battery, Home Depot Grill
Twilightzero is offline   Reply With Quote
Old 04-10-2008, 01:27 PM   #7
Tim Vance
EOC Rank: Iron
2003 2WD EX AT
Tim Vance's Avatar
Send a message via MSN to Tim Vance
I join the consensus here...
I've heard of a few ppl having side windows broken, and I even recall someone, once years ago, reporting a rear window blowing out - but I think it was determined to be related to excessive heat, and a flaw in the glass....
But having a window shatter, because someone slammed a door? No i don't think so...
Even if the over pressure so so high, that it caused the cabin pressure to rise that high, then a window, in it's entirety should blow out (the whole window 'pops' loose), the window should not shatter...
I mean come on - they are safety glass. i don't know what exactly the safety rating is on the rear windows, but it's my understanding that the window would only shatter if something impacts against it, or the frame is warped...
Do you have comprehensive insurance? If the dealer won't warranty it, call your insurance, and see if they will cover it...?
__________________
Canadian 'Y', Key less entry, Alarm, carpet floor mats, bungees, Wheel locks, 'Element' 3rd brake light, Cloud Rider Stainless Steel Grill, Fog Lights, Shen's blinker mod, Canada stickers, 'Empire's Dark Side mod', RAM Laptop holder, window tint, class III hitch, window vent visors, Michelin LTX, Side Steps, 'Memory foam' seat covers, driver side armrest, Hunter Bull Bar
Tim and Elaine are Honoured to be amongst the Founders of the Misfits est. 14 July 05
Tim Vance is offline   Reply With Quote
Old 04-10-2008, 01:38 PM   #8
Alchemy
EOC Rank: Helium
2003 4WD DX AT
Alchemy's Avatar
Just a quick note to make sure we are all on the same page. Safety glass does not mean it is unbreakable. It actually breaks quite easily under the right circumstancers. It merely means that it is tempered so when it does break it ends up in tiny polygon shaped pieces that won't impale the occupants during a wreck.
My friend just had the same thing happen to his sunroof except it occured while he was driving. We puzzled over the internal pressure possibility for awhile, but I think that is highly unlikely.
__________________
Old 04-10-2008, 02:32 PM   #9
Genom
MØÐΣ®ΔTΩ®
2004 4WD LX MT
Sunset Orange Pearl (SOP)
Genom's Avatar
Send a message via AIM to Genom
Yes, there was a member who had their rear hatch glass blow out without any impact.
Maybe Honda just makes sh!t glass.:rolleyes:
__________________
Element "Hidden Satellite Antenna Trick"---Dune Buggy Photo Gallery
They call me James...
Genom is offline   Reply With Quote
Old 04-10-2008, 05:43 PM   #10
Tim Vance
EOC Rank: Iron
2003 2WD EX AT
Tim Vance's Avatar
Thanks Alchemy..In my round about way that's what I meant when I said that the glass should only break if impacted...meaning shattered...
But automotive safety glass has a certain amount of rigidity and strength, to be able to withstand certain stresses...
My point is that the op said his window shattered when someone slammed the door. I was trying to agree with others that the dealer saying they must have slammed the door really hard is bs...
If someone slammed the door really hard, then the glass in that door should have broken, or one of the windows in an adjacent frame, not the glass in the rear side window!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Request: side window mods Solid Do-It-Yourself / Mods 10 05-23-2007 02:48 AM
Recurring streaks on Front Window Interior treetopflyer Wax on, Wax Off 5 05-04-2006 03:07 PM
auto-down passenger window cletus Do-It-Yourself / Mods 16 06-17-2005 09:05 AM
Side Step thoughts... gfxguy 'E'ccessories 2 03-02-2005 12:59 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
