2007 100,000 mile service? - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Maintenance and Service
Notices
Reply
Thread Tools Display Modes
Old 06-08-2008, 04:37 PM   #1
wadecool
EOC Rank: Helium
2007
I have 103,000 miles on my 07 E and am wondering what maintenance should be done. I've been changing the oil every 3000 miles. I've given up trying to decifer those maintenance codes. Any help is appreciated.
__________________
07 EX auto 4wd
Uniden PC68 cb
5' K40 antenna
01 Dodge Ram 2500 4x4 Cummins Diesel 5spd
4 1/2inch straight pipe exhaust, K&N high flow air filter, Superchips tuner, 400hp/700lbs tq
33inch Maxxis Buckshot mudders
wadecool is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-08-2008, 05:07 PM   #2
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
You could follow the 2006 schedule.
__________________
Old 06-08-2008, 09:29 PM   #3
Alaskan_Toaster
2007 4WD EX MT
Tango Red Pearl (TRP)
Alaskan_Toaster's Avatar
Location: Winter is here, first snowfall is now history
Geez, and I thought turning over 20k on mine today was a lot.....
Since you do that much driving, might suggest changing your oil less often (you're on the highway most, right?), using synthetic oil with a GOOD filter. Not trying to insult your intelligence or maintenance (preventive maintenance is ALWAYS a good thing), I'm just thinking about how much you're spending.....
5-7K miles between OCs should be more than plenty, again, based on your mileage.... :rolleyes::):D
You should be in the million mile club by, what, 2015??!!
__________________
Mods so far - Thule rack, K&N, ,
, leather shift knob and boots, HIDs and LEDs, G-bags, Ridgie remote key,
, WT visors, MTF.....
Instead of giving a politician the keys to the city, it might be better to change the locks.
Alaskan_Toaster is offline   Reply With Quote Quick reply to this message
Old 06-09-2008, 09:59 AM   #4
wadecool
EOC Rank: Helium
2007
I don't have a 2006 service schedule. I don't pay myself since its a company car and I have a valvoline fleet card for any maintenance they provide. I drive it pretty hard, so I want to take care of the servicing schedule, such as tranny, differential service, etc. Any advice is appreciated.
__________________
07 EX auto 4wd
Uniden PC68 cb
5' K40 antenna
Old 06-09-2008, 01:21 PM   #5
ramblerdan
2004 4WD EXS MT
ramblerdan's Avatar
Quote:
https://techinfo.honda.com/rjanisis/...606MAINIXA.pdf
__________________
Old 09-05-2011, 05:23 PM   #6
tnjman
EOC Rank: Hydrogen
2005 4WD DX AT
Rallye Red (RR)
RamblerDan - your link does NOT work!
FYI, the link you left leads ONLY to "page #1" of the PDF, it does not lead to the entire document.
tnjman is offline   Reply With Quote Quick reply to this message
Old 09-05-2011, 05:50 PM   #7
tnjman
EOC Rank: Hydrogen
2005 4WD DX AT
Rallye Red (RR)
Regards 2005 Element 100k maintenance
I am almost at 100k, and I keep getting these notices - one says $600-ish for the dealer to do the 100k maint - which seems to include changing the timing belt - is that needed - or??
So, if these Elements are like the Mazda, they have the 'plastic-like' timing belt vs. ye olde tried and true 'timing chain,' and it has to be changed about every 120k miles. In the guides so far, I find NOTHING about recommended changing of "timing belt."
ALSO: Conventional wisdom ALWAYS has held that you DO NOT change the transmission fluid, UNLESS you have some issue or problem, or you know for a fact that it has gotten dirty. It is a 'sealed system' - and in the old days, some folks lived by "Change tranny fluid every 100k!"
With the newer engines, etc., about 10 years ago, I was told "NEVER change tranny fluid (in an automatic) unless there is a problem."
Has that changed? Is there any real benefit? I suppose, like with regular oil, the tranny fluid can lose some of its... viscosity and effectiveness as a lubricant?
Yes, I am a conservative driver. Have not flipped the 100k yet.
The index page that RamblerDan sent the link for, well, it did not allow any of it's own "index page links" to work, so it basically only allowed me to view the index page itself.
BUT I CONFIRMED IT IS A Firefox problem, so
My apologies to RamblerDan.
If you use IE to go to the link that RamblerDan provided, then the index page links in the PDF work just fine. I shall make a note of that.
BUT, due to the freaking way that this PDF rendering of the Owner's guide works with BOTH IE & Firefox, basically it allows ONLY a few pages to be viewed at a time! SERIOUSLY ?!?!?!? Guys, ladies, folks, HOW do we download the ENTIRE Element Owner's Manual in PDF form?
Using the link RamdlerDan sent, I can download only "one section at a time," which is a HUGE waste of time.
Old 09-05-2011, 06:24 PM   #8
chelement3
EOC Rank: Oxygen
2010 4WD EX AT
chelement3's Avatar
Disregard. I didn't read the next post.
__________________
CHElement1: 2003 EX 2003-2007
CHElement2: 2007 EX 2007-2008
CHElement3: 2008 EX 2010-2016
CHElement4: 2010 EX 2016-. . . .
chelement3 is offline   Reply With Quote Quick reply to this message
Old 09-05-2011, 09:09 PM   #9
desinia
EOC Rank: Neon
2008 4WD EX 5AT
desinia's Avatar
Oooch! It must be a problem with one of those new flaky versions of Firefox then 'cause that's what I use and all the links are functional.
If you can't find the manual in one, giant, easy to download file, you can either download each link separately by right clicking (Um, I forgot. Find out what's wrong with your copy of Firefox first) or use any freeware web sucking program to pull all of it.
__________________
The Honda ELEMENT
Wherever you are, it's in its own.
YOU WON a Honda dream vacation! *
*(Travel, food and lodging not included. All other expenses are the responsibility of the contestant.)
desinia is offline   Reply With Quote Quick reply to this message
Old 09-06-2011, 08:58 AM   #10
ramblerdan
2004 4WD EXS MT
ramblerdan's Avatar
Or you can buy a paper copy from Helm Inc.
As for the online version, personally I think it's awfully nice of techinfo.honda.com to provide it for free.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My 100K E! :) nelphos Image Gallery 39 06-09-2008 08:47 PM
Dogcars dot com LmentalMastiffs Truth About Cats, Dogs and The E 3 12-27-2007 05:24 PM
Took for 30k mile service and they say my rear brake is due. Is it normal? skuba Maintenance and Service 10 07-19-2006 04:27 PM
30,000 Mile Service Time vegasbaby Under The Hood / Performance 31 02-12-2005 05:58 PM
6000 or 10000 mile service? Presta Under The Hood / Performance 6 11-08-2004 10:45 PM
