Cold Start Stalling HONDA TECH - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 11-08-2008, 11:38 AM   #1
bennyboie
EOC Rank: Hydrogen
2005 4WD EX
Nighthawk Black Pearl (NBP)
Send a message via AIM to bennyboie
Exclamation Cold Start Stalling HONDA TECH
Hello..
It appears that numerous people have been facing this issue:
On a cold start, the E will idle rough, bog, or stall out when decelerating. After warming up, the E will be fine...
I stopped by the dealer today, and I was told that they've seen this issue numerous times on the E as well as the CR-V. He told me its either the Idle Control Valve, the EGR, or the Throttle body, the latter being the rarer case. I also found valve adjustments to help?
Ive already replaced the Idle Control Valve, thinking of the EGR next, but Id rather have a better approach than changing parts from the ground up hoping to get a fix. Any insights or ways to accurately diagnose the issue?
Please help!
bennyboie is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-08-2008, 12:51 PM   #2
Some Mook
EOC Rank: Helium
Some Mook's Avatar
It cannot be an EGR issue
The Element (or 2002 and up CRV, for that matter) is not equipped with an EGR valve.
__________________
mook /muk/
–noun: Slang. An insignificant, contemptible, or incompetent person.
"Ah, women. They make the highs higher and the lows more frequent."
Friedrich Nietzsche
(not my website)
Some Mook is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 03:57 PM   #3
cskyun
EOC Rank: Hydrogen
stalling E
I had similar issue and I am copying/pasting this from another thread..
Had it been my car, I would have tried cleaning the throttle body like others have suggested.
>>>>Update on 06E stalling issue..
Here is what the dealer charged my company (it was a company car so I did not even bother: liability issue..)
cleaner, top engine..$4.28
gasket, cyl HD CVR..$13.55
perform top engine cleaner..$210.00
adjust valves and recheck..$117.60
"misfire from cylinder #1 causing rough running swapped coils and it did not change. MAP sensor high reading need to adjust valves after top engine leak performed top engine cleaner adjusted valves and rechecked ok now."..verbatim
Just to be clear, I had issues with stalling for initial 10 to 15 min but once the car is running, never had a rough engine issue.
I think my company got ripped off but what the heck, it is not my money and those poor guys have to make a living too. Maybe I have "sucker' written all over my face..
Thanks for all the help guys.<<<<
cskyun is offline   Reply With Quote Quick reply to this message
Old 03-20-2009, 07:22 PM   #4
bennyboie
EOC Rank: Hydrogen
2005 4WD EX
Bump
STILL HAVING THESE PROBLEMS!!!! Im reading of others with similar problems, but no answers... anyone?
Old 03-20-2009, 09:45 PM   #5
jivenene
EOC Rank: Hydrogen
2003 4WD EX AT
Quote:
Hi, you have a 2005? how many miles on it? you already replaced the idle control solenoid?
have you replaced plugs? done valve lash adjustment?
if you read cskyun post above, the dealer who did the work checked for air leaks on the intake system, and found none. he noticed a out of spec reading on his scanner for the MAP sensor, and determined valves needed to be adjusted. after that was done, he claimed it was fixed.
so unless you take it to a shop, i would go the same order.
1) check for vacuum leaks
2) change plugs if excessive mileage (new plugs should only help things)
3) adjust valves
i think our motors come stock with iridium plugs, which theoretically go 100k mi until honda claims they should be changed, but i beleive in PM and am changing mine out at 55k mi.
if the problem persists, i am stumped.
jivenene is offline   Reply With Quote Quick reply to this message
Old 05-12-2011, 12:34 PM   #6
Brian Fischer
EOC Rank: Hydrogen
2007 4WD EX MT
Tangerine Metallic (TM)
I had the stalling when cold issue and did the valve adjust.
Problem 100% solved!!
All exhaust valves and one intake valve were ridiculously tight. Having made the adjustments my element is running perfectly and smoother at idle than new.
Brian in Atascadero, CA
2007 Honda element, manual transmission
Brian Fischer is offline   Reply With Quote Quick reply to this message
Old 10-11-2011, 10:41 PM   #7
cheeks
EOC Rank: Hydrogen
2003 4WD EX AT
Galaxy Gray Metallic (GG)
my E has started stalling when i start it up
im having a similar problem with my E...i recently started getting the maint light flashing 10 times at startup. and now my E seems to stall a bit when i start it up. Like its struggling. Can it be because of the maint light thats just started flashing?! i havent taken it to a mechanic yet. My husband is good @ hondas but he's been working alot lately so hasnt been able to check it out for me yet :(
figured i'd get some ideas of what it could be so i can let him know any advice i get!
thanks!!
cheeks is offline   Reply With Quote Quick reply to this message
Old 10-12-2011, 11:15 AM   #8
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Welcome, Cheeks.
Just to be sure, you mean the "Maintenance Required" indicator, not the check-engine light, yes?
More info on the Maintenance Required indicator on pages 70–71 of your owner's manual.
As for the rough running, the most popular causes seem to be valves out of adjustment, dirty throttle body, or bad idle-air control valve. How many miles on that 2003, and has it ever had the valves adjusted or TB cleaned?
__________________
Old 10-12-2011, 03:06 PM   #9
cheeks
EOC Rank: Hydrogen
2003 4WD EX AT
reply to ramblerdan
car has about 128k on it & nope, no adjustments or cleaning has been made that we know of....we purchased the car used at the begining of the year and dont have the owners manual but im sure we can figure out based on this thread how to reset the maintenance light.
We will look into the adjustments and cleaning! thanks so much!!
- you know what else happened that was odd too is that the engine light came on for two days and then shut back off....i havent seen it again.
Old 10-12-2011, 04:07 PM   #10
ramblerdan
2004 4WD EXS MT
ramblerdan's Avatar
Relevant threads
Valve Adjustment with pictures!
DIY: Clean your throttle body
• Resetting the Maintenance Required Indicator
(stickeyed in the Maintenance and Service section)
Owner's manual
You can order a version from Helm Inc. here.
Owner's manuals in PDF format, courtesy of techinfo.honda.com:
20032007
20042008
20052009
20062010
Note: The 2003–07 PDFs are are internally linked, with discrete files for each section, so can be viewed online. The 2008–10 versions are very large, monolithic files, so should be downloaded to your computer before viewing. (Right click, save-as.)
Quote:
It should have stored a trouble code. You can buy a code reader and pull the code yourself, take it to a shop, or see if a local auto parts store will pull it for you for free.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Honda Reveals Accessory Concepts for Civic and Ridgeline at 2008 SEMA Show [11.4.8] T Mac Headlines 3 01-06-2009 07:26 PM
Honda Canada sales up 5 percent in January 2006 [2.1.6] T Mac Headlines 0 02-01-2006 10:37 PM
Honda Keyless entry module needed with remote start? br6tt 'E'ccessories 7 02-05-2004 11:18 AM
