idle air control valve (2003-06) - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 07-02-2008, 08:43 PM   #1
manu06
EOC Rank: Hydrogen
I think I need to clean or replace my idle control valve. When I start my
Element it idles around 500-600 rpm. With the A/C on it idles a little higher.
It has been stalling out at intersections and when I turn. I got a code P0172
which indicated the fuel mixture was too rich. Where is the ICV located ? I assume on the throttle body. Does anyone have a picture of one ?
manu06 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-05-2008, 03:12 AM   #2
barrel
EOC Rank: Hydrogen
2003 2WD DX MT
Eternal Blue Pearl (EBP)
Does any one with a 2003 DX 2WD manual transmission have or had problems with the engine RPM's fluctuating concerning the idler air control valve? I got about 114,000 miles on my E. Any one tried cleaning the IACV? Much Mahalo's for feed back!
__________________
shi-5
barrel is offline   Reply With Quote Quick reply to this message
Old 12-18-2008, 03:24 PM   #3
reedkantor
EOC Rank: Hydrogen
Cool idle air controller out at 39,000
a very unusual part failure....car started stalling a few times and managed to restart it and get it to pompano honda here in south fla. a part they said was "like the old carburetor" went and had to special order it...called an idle air contoller, cost $100 bucks plus over 200 in labor. go figure....otherwise nothing else has gone wrong since i bought it in oct. of 2004.
__________________
reed kantor
reedkantor is offline   Reply With Quote Quick reply to this message
Old 12-18-2008, 08:41 PM   #4
josh302
EOC Rank: Hydrogen
2003 2WD EX AT
was your engine light on? did it come on at all?
josh302 is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 03:09 PM   #5
reedkantor
EOC Rank: Hydrogen
idle air controller
yes, the light came on when the car started stalling all of a sudden. i got it started and then it stopped and started a few more times and i finally got to the dealer, who was very close.....
__________________
reed kantor
Old 08-07-2009, 11:57 AM   #6
RdE_Rnr
EOC Rank: Oxygen
2003 2WD EX AT
RdE_Rnr's Avatar
Idle Control Valve Replacement Help!!!
Okay, Car won't start this morning, first I thought it was the Battery but isn't, finally got started but noticing low Idle, usually at 1300 rpm and comes down in few mins. 2 strong suggested mechanics states ICV now, my questions/help needs, I got the parts from Honda Dealer...does anybody have a pics suggestions on how to replace it or have done it? I know it's under the throttle body, is it simple as taking the 2 cross screws and wire harness? Plug and play? Any help would much so appreciated.
__________________
RdE_Rnr is offline   Reply With Quote Quick reply to this message
Old 08-08-2009, 08:51 PM   #7
RdE_Rnr
EOC Rank: Oxygen
2003 2WD EX AT
RdE_Rnr's Avatar
Idle Control Valve
bump!!!..................do i need to take the whole Throttle Body to just replace the ICV only? and if any reset thing to do later when done?
__________________
Old 08-10-2009, 10:41 AM   #8
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Prior8t2000 has posted a throttle-body DIY that might be helpful.
__________________
Old 10-27-2010, 05:05 PM   #9
Bandicoot
EOC Rank: Hydrogen
2004 4WD EX MT
Shoreline Mist Metallic (SMM)
Erratic idle - SOLVED!
Long time reader, first time poster.
In any case, the past few days, my 2004 Element MT with 107k miles had erratic idle. The idle would hunt from 1k-3k, and sometimes pulse at 1k-1.5k. Driving was a pain as off throttle or lo throttle, the car would jerk from the pulsing.
Codes that were thrown were P0507 and P2279. I read in a few posts here that it's likely a vacuum leak (didn't find any) or a dirty IACV and cleaning it would help. Well, I cleaned mine THOROUGHLY twice. It would spin, but still just barely, just barely, stick at some points in the revolution. Anyone less anal would think it'd be fine. However, that didn't solve the problem.
The actual IACV P0511 code never showed up. So, I was skeptical about replacing the IACV. However, lo and behold, after replacing the IACV (and becoming $128 poorer) and letting the idle relearn itself, everything is now butter. Oh, replacing the throttle body gasket at the same time isn't a bad idea either ($4).
YMMV, but I thought I'd post this to show an actual solution to a seemingly common problem.
Bandicoot is offline   Reply With Quote Quick reply to this message
Old 10-27-2010, 07:32 PM   #10
ramblerdan
2004 4WD EXS MT
ramblerdan's Avatar
Thanks for that, Bandicoot, and welcome.
Just to be clear, the idle air control valve is what Honda calls "valve set, rotary air control," p/n 16022-RAA-A01?
Throttle body gasket: Honda p/n 16176-RAA-A01
P0506: Idle control system RPM lower than expected
P0507: Idle control system RPM higher than expected
P0511: Idle air control system RPM higher than expected
P2279: Intake air system leak detected
__________________
Sponsored Links
Advertisement
Reply
Tags
air , control , iacv , idle , p0507 , p2279 , valve
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bad transmission pressure control valve? andyf80 Problems & Issues 10 11-25-2016 02:55 PM
