Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Do-It-Yourself / Mods
Notices
ElementOwnersClub.com is the premier Honda Element forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Reply
Thread Tools Display Modes
Old 06-22-2009, 12:56 PM   #1
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Sunset Orange Pearl (SOP)
Lmeans's Avatar
How to install the eBay HID Projectors
These are the projector lenses from eBay seller Hiking1978 several people have installed already.
I will have a complete detailed write-up soon.
For now, here is a slideshow with captions. More pics will be added.
__________________
...never knows best
Sometimes known as:
The one with the dirtiest Element.
The guy that made it to The Racetrack and back in one piece!!
Lmeans is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-22-2009, 01:12 PM   #2
HockeyGuy21
EOC Rank: Carbon
2005 4WD EX AT
Rallye Red (RR)
HockeyGuy21's Avatar
AMAZING WRITEUP! thank god someone did it! i was gonna do it next time i got into mine but thanks for the slideshow
__________________
~_____
| __|__\___
[(o)|___(o)]
2005 Rallye Red AWD EX Under Construction
CLICK BELOW TO ENTER THE CONSTRUCTION ZONE
http://www.cardomain.com/ride/2980224
HockeyGuy21 is offline   Reply With Quote
Old 06-22-2009, 11:37 PM   #3
5spdSOP
EOC Rank: Hydrogen
2004 2WD EX MT
5spdSOP's Avatar
I am soooo gonna do this now when I get more $$$
Will I still be able to use a regular halogen bulb if I do not get HIDs right away?
I was a little concerned when I saw the picture of the hole for the bulb when you said that larger bulb would not fit
5spdSOP is offline   Reply With Quote
Old 06-23-2009, 12:31 AM   #4
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Lmeans's Avatar
More install info...
The current cost is $114.98 for the projector lenses and $45.98 for the ballasts. The price keeps dropping over time too, so it may get even cheaper!! The projector lens kit has the bulbs and all the wiring you need, minus the ballasts. His kit looks like every other plug-and-play HID kit on the market with the exception that this kit comes with projector lenses. It is all no name Chinese stuff and though it does not feel like the best quality stuff out there, I felt confident enough to install it.
The sellers name is Hiking1978 and his store is called Xeaz. He has thousands of things for sale so search the store for “Projector Len” (spelled just like that). For the ballasts, search for “Spare Ballast”. You need two normal (non-slim) 35watt ones. The items are shipped from Shanghai, China and took about 10 days to arrive.
Total cost of $160.96. Not bad considering you will have some pretty unique looking lights that kick out a ton of light, plus the added bling of halos. They will flash on and off with the OEM remote. You do need to purchase heavy duty zip ties, and I recommend a better sealant than the one provided, but I don’t know the best kind or brand. Also get some 16 gauge wire too, 15’ feet is more than enough. There are a lot of products that remove sealant but I was worried about damaging the headlight plastic so I went without using it but for me the hardest part of the mod was getting the two headlight pieces back together and I bet that removing the old sealant would have made a lot less painful.
Tools you need:
Flathead screwdriver (a good sized wide one)
Ratchet with 6” extension
8mm and 10mm sockets.
A tool for stripping and cutting wire. Are they called wire strippers?
Electrical tape.
12” zip ties.
Any size hammer.
An oven, a cookie sheet, and a wet towel.
And maybe if you are a wuss like me, some gloves for touching the headlight after it comes out of the oven.
Admittedly, I am completely inept at automobile modification, so this probably took me longer than it would take you. I went very slow to make sure everything was right. The provided instructions are pretty vague but the wiring process is fairly self explanatory, even for someone like me. I got everything working with the headlights sitting on milk crates in about 10 hours with breaks here and there. The next morning I put everything back together and that took an hour or so.
__________________
...never knows best
Sometimes known as:
Old 06-23-2009, 12:34 AM   #5
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Lmeans's Avatar
No you will not. The projector uses an H2C bulb. The kit comes with 6000k HID bulbs already installed though.
__________________
...never knows best
Sometimes known as:
Old 06-23-2009, 12:43 AM   #6
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Lmeans's Avatar
It's hard to take photographs of the actual color of the bulbs because my camera adjusts to make it white. At night, they look pretty white but it's obvious they are blue. They look way better than any other HID kit I have seen though. Lots of people have retro fitted HID's here in SoCal, and most look very ghetto.
One thing I have noticed is that although you get a lot more light output, it appears that there is much less contrast in what is being illuminated. I plan to get 5000K or even 4300K bulbs to correct that.
__________________
...never knows best
Sometimes known as:
Old 06-23-2009, 01:11 AM   #7
chefjames
EOC Rank: Oxygen
2007 4WD EX AT
Atomic Blue Metallic (ABM)
chefjames's Avatar
Loren, nice pictures and nice write up, and hopefully I will have my sometime next week.....
__________________
work like you don't need money
love like you have never been hurt
and dance like no one is watching
chefjames is offline   Reply With Quote
Old 06-23-2009, 01:58 AM   #8
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Lmeans's Avatar
Be sure to get the right bulbs
Just discovered something about the bulb used in the projector.
It does not use an H4 bulb, the H4 connection is further down the line and irrelevant. This setup uses a D2C bulb.
So anyone looking for a replacement bulb, you should purchase a D2C bulb.
The photo below shows a that you can also use a D2R and D2S bulb too.
The bulbs ship already installed in the projector so there no work on your part. I pulled one out just to have a look and found this :confused:
I straightened it out and even though the white piece is broken it works. The other bulb is the one with the yellow spot.
__________________
...never knows best
Sometimes known as:
Old 06-23-2009, 02:02 AM   #9
Lmeans
EOC Rank: Helium
2005 4WD EX AT
Lmeans's Avatar
Quote:
Lemme know if you want any help. SD must be nice this time of year.
__________________
...never knows best
Sometimes known as:
Old 06-23-2009, 03:11 AM   #10
OUZO Power
EOC Rank: Oxygen
2006 4WD EX-P AT
Just did mine.
__________________
- 05 Honda Odyssey EX-L Nav/RES
- 01 Honda Prelude Special Edition (Sneezing at 8psi between shifts)
- 99 Honda CR-V Special Edition AWD
- 93 Honda Civic DX Coupe
OUZO Power is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
SC Philips HID Kit Install... warning, lots of pics! FrostyMug Exterior 23 03-16-2010 06:01 PM
Yet Another Avic-D3 Install eddieroger Mobile Electronics 14 05-01-2008 09:26 AM
Help w/ Polk Momo Component Install? dancetiludrop Mobile Electronics 3 08-11-2006 12:12 PM
Fog Light and Front Bumper Trim Install Bucko2006 Exterior 12 07-25-2006 11:56 PM
My Foglight Install... chapds 'E'ccessories 2 03-21-2004 11:22 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
