This week on Patty's Element the battery died .
As I had stated in another thread, I had done some shopping. I finally made a decision, and went with the Walmart battery.
I did the usual things with the 9v battery to maintain all the car's settings. Positive to the Positive lead, and the negative side to the body ground.
After removing the battery, I noticed that the Engine ground was cruddy. So you know I had to clean that up. The bolt needed cleaning also.
After I got all that taken care of I could put in the battery.
Not bad for 85.00$ I did need to replace the hold down clamp with something wider. Remove the plastic tray and Bedliner the sheet metal battery stand. Some bending of the tabs was required to obtain a proper fit.
Other than that not much to report.
Next post will show the finished project!
