Help Fault Code P115 - Check Engine Light On...Fuel System Problem? - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 02-12-2010, 08:14 PM   #1
onetracker
EOC Rank: Hydrogen
2003 4WD EXS MT
Cargo Khaki (CK)
Yesterday, got gas and the guy topped of my tank; tried to stop him to no avail. One hour later the check engine light came on. Went down to Advance Auto Parts to read the code. Code = Manafacturer Control Fuel Air Metering p115 was the fault code. I am thinking that there is either fuel in the avaporator canister or the gas cap is bad (seems unlikely). Any ideas? Thanks in advance. Bill
onetracker is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-14-2010, 01:24 AM   #2
kitkat123474
EOC Rank: Carbon
2004 2WD DX AT
Satin Silver Metallic (SSM)
kitkat123474's Avatar
Send a message via MSN to kitkat123474 Send a message via Yahoo to kitkat123474
i'm guessing your fuel cap is bad? replace that to see if it clears
__________________
sweeeeeeeeeeeeeeeeetttttttttttt
kitkat123474 is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 05:24 AM   #3
NismoGriff
EOC Rank: Carbon
2004 4WD EXS MT
NismoGriff's Avatar
Quote:
Not long after buying my Element used, I was filling up and topped off the tank. Shortly after I got an erratic engine idle and a CEL. I don't remember if that was the exact code I got, but I could make the irratic idle come and go with removing/reinstalling the gas cap. I let the engine run for a while and kept removing/reinstalling the gas cap. It finally smoothed out completely and then I cleared the code. I haven't 'topped' it off since and I have never had the issue again.
It's been a while, but I am pretty sure there are other threads on here discussing similar issues.
__________________
AVIC D3 with bluetooth, XM, Ipod cable and rearview camera. Both sat. antennas installed using the
. Sony XM-1S mono amp running a
1508 subwoofer. Honda exhaust finisher. AVS Ventvisors. EP3 shift knob. Shen's
mod, and bh241's
mod. SC console. UHaul hitch. OEM Foglights. Lower grill guard. Inside electronic hatch release. Hornet security system with window control module.
NismoGriff is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 09:23 AM   #4
wipeout97
EOC Rank: Helium
2003 4WD EX AT
Nighthawk Black Pearl (NBP)
Just FYI, the fuel cap is supposed to be replaced every 2yrs or 24 months. Prior to working in a shop I thought this was complete BS but now, however, I've seen and experienced why they recommend this. Any local auto store can help with new fuel caps much cheaper than OEM.
__________________
Molybdenum Disulfide - Are you using it yet?
wipeout97 is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 03:37 PM   #5
Honda Tech
EOC Rank: Helium
2003 4WD EX MT
Honda Tech's Avatar
If the OP would list a valid (ie: complete) DTC, there might be a better resolution to the concern than what will result from the conjecture and outright guessing that is going on in this thread right now.
Were I to guess, the DTC may have been a P1157, which would be an A/F sensor circuit high voltage fault indication
__________________
"Success is 99% Failure"
Soichiro Honda
(not my site)
Honda Tech is offline   Reply With Quote Quick reply to this message
Old 02-19-2010, 11:51 AM   #6
onetracker
EOC Rank: Hydrogen
2003 4WD EXS MT
Cargo Khaki (CK)
My OBD II scanner only gave me the p115 code and the previously mentioned description. How can I get additional information?
Old 02-19-2010, 12:43 PM   #7
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Honda Tech is right—the codes are four digits. (I don't find any P115x codes, but FWIW there is a P0115, Engine coolant temperature circuit malfunction). Best to try another scanner.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Check engine light jlauver Under The Hood / Performance 9 01-21-2017 02:25 PM
Check Engine Light MarcelV Problems & Issues 2 07-28-2009 08:35 AM
Engine Light on, Code P0498 Beauhonda Problems & Issues 3 07-17-2008 08:16 PM
HELP - Engine Cutting Out, Check Engine Light On MacGyver Problems & Issues 6 11-07-2007 05:39 AM
