[FONT="]HD GRILL GUARD MOD: UPPER GRILL[/FONT]
THIS PROJECT (DONE MAR 4-5, 2010) IS DETAILED OUT FOR -ONLY- 2009 AND 2010 MODEL’S GRILLS. THERE IS A BIG DIFFERENCE IN TERMS OF THE UPPER GRILL OPENINGS AND I STARTED THIS AS A LOWER GRILL MOD. A SEPARATE THREAD IS SET ASIDE (SORRY MODS!) TO DETAIL THE “LOWER GRILL GUARD MOD” WHICH INCLUDES A DETAILED ACCOUNT OF THE BUMPER REMOVAL..
What follows is my 2009-10 Upper Grill Guard Mod using the metal Home Depot gutter screen without and with paint… For those of you that are handy, you’ll appreciate the detail… I did look at the other threads on this mod and did mine this way so that those of us who are not mechanically inclined (READ DISCLAIMER) have a resource to figure this stuff out… To those folks who are like me, by all means, follow this account and my bumbling hands to the end…! I’ve pared this down from 150+ photos to what you have before you…
DISCLAIMER: I AM NOT MECHANICALLY INCLINED BY ANY MEANS AND I TOOK THESE PICTURES IN CASE I FORGOT A STEP OR PROCEDURE ALONG THE WAY. PLEASE READ THE ENTIRE THREAD FROM BEGINNING TO END AND IF YOU CANNOT SAFELY HANDLE 30-40 LBS, GET ANOTHER SET OF HANDS TO HELP YOU. I DID THIS PROJECT AFTER 7 MONTHS OF OWNERSHIP BECAUSE IT TOOK ME THAT LONG TO GATHER UP ENOUGH COURAGE TO DO THIS ON MY OWN. I’M A BIG GUY AND DID THIS BY MYSELF BUT BECAUSE I ADMIT TO BEING AN IDIOT AT TIMES, I TOOK THE PICS TO COVER MY BUTT. THE PROJECT TOOK 2-AFTERNOONS TO COMPLETE (BECAUSE OF PAINT DRYING TIMES) AND THE LAST PHOTO WAS TAKEN ON A SUNNY DAY TO SHOW THE FULL RESULTS OF MY GOOD ‘OL LUNCH BOX. NOW WOULD BE A GOOD TIME TO CLEAN OUT THE FINS OF THE CONDENSER/RADIATOR FRONTS NOW THAT THE BUMPER IS OFF. DO THIS PROJECT AT YOUR OWN RISK! WORK SAFELY AND HAPPY MODDING!
List of tools used:
Home Depot / Wal-Mart purchases:
[FONT="]UPPER GRILL GUARD MOD:[/FONT][FONT="] (27-PHOTOS)[/FONT]
Step One: BUMPER REMOVAL (REFER TO PAGE 3 ON THE PDF FILE FROM H-AND-A)
Follow this LINK or follow here:
http://www.handa-accessories.com/element/10fogs.pdf
On page 3 of the D-I-Y Fog Lights Installation Instructions (from our good friends at H and A), you’ll see the diagram of where all the clips, bolts and screws are to remove the bumper. Or, you can go to my HD Lower Grill Mod thread HERE.
Step TWO: (OPTIONAL)
Remove the upper grill assembly from the bumper. Clips are marked with arrows and I only used the flat-head screwdriver to pop the clips off. If you decide to skip this, go to Step THREE:
PHOTO: Upper grill removed from bumper.
A better view.
Step THREE:
Time to draw a template. Use a marker and tin snips. I planned on bending down the grill guard along the sides of the grill to eliminate the need to have to drill holes on the sides to mount the screen. SPECIAL NOTE: EXTEND THE TEMPLATE BORDER SIDES BY ONE-INCH!!!
CONTINUED...
List of tools used:
- Screwdriver-flat head: to pop-out clips
- Screwdriver-Philips: screw removal
- 10mm socket & wrench: stepped bolt removal
- Black marker: to mark my template
- Leather gloves: to prevent cuts on my hands
- Tin snips: to remove excess metal
- Wire cutters: to trim zip ties
- Blanket-to lay the bumper on
- HD-Gutter Guard $2.16 each (I got 2 for Upper and Lower Grill Mods)
- WM-Spray Paint: Rust-Oleum Automobile Primer (Dark Gray) $3.97
- WM-Spray Paint: Rust-Oleum Flat Protective Enamel (Black) $3.97
- WM-Leviton 4-Inch Cable Ties (Black/100-count) less than $2 (had these for a long time/need 10-for this project)
- Total: $14.26 + 9.75% tax = $15.65
A better view.
Step THREE:
CONTINUED...
