How to replace rear stabilizer / sway bar links - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Maintenance and Service
Notices
Reply
Thread Tools Display Modes
Old 04-18-2010, 09:33 PM   #1
mrpolice
EOC Rank: Hydrogen
2004 4WD EX AT
Satin Silver Metallic (SSM)
mrpolice's Avatar
No one had a how to on this so I made one. Many have complained about a groan and rattle from the rear suspension. Some suggested replacing the sway bar bushings. For some that worked, for me it did not. It was my stabilizer end links a.k.a. sway bar end links. Here is how I got them off...
__________________
Jon Miller
Cleveland, Ohio
mrpolice is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-18-2010, 09:40 PM   #2
mrpolice
EOC Rank: Hydrogen
2004 4WD EX AT
mrpolice's Avatar
Next steps...
You can beat the crap out of these and you wont hurt your E unless you miss. Once the ball joint looking ends are exposed - put a vice grip on them and using a 14 mm socket or impact gun (like I did) take em' out. You have to use a vice grip or a strong friend with pliers because that mofo will just spin if you torque on it.
The new ones go right back in their place. They are right and left specific however. Stick an allen wrench in the end of the link - the tip of the threaded part (the only place it will fit) - then use a 14 mm open ended wrench to tighten it down. Hold the allen wrench steady as you go. I spent $15 and bought a 14 mm ratcheting open ended wrench to make it go faster. While the car is up in the air, tighten it but not all the way - just so it is snug. Then use a jack and jack up the rear hub you are working on. When you see all the vehicle's weight is on the jack - then tighten down the link ends all the way. - You're done. I spent $62 total on the parts.
I did both sides, the second one was about 3x as fast as the first.
My car has groaned for a year and after this fix it feels like a new car although Im sure it rides the same it's just so quiet. After I was done (last picture) I sprayed brake cleaner all over to get rid of the penetrating oil. Then I spray flat black high temp paint all over everything so any scuffs I made wouldn't rust.
All the other rust you see is typical for this climate where they use salt on the roads 6 months outta they year - bleh!
If this posts helps you let me know! This forum has saved me $1000's so far...
__________________
Jon Miller
Cleveland, Ohio
Old 05-28-2010, 11:10 AM   #3
LunchBoxDriver
EOC Rank: Carbon
2009 4WD EX 5AT
Polished Metal Metallic (PMM)
LunchBoxDriver's Avatar
Just wanted to say NICELY DONE...!!! *applause*, *applause*...!
LBD
__________________
The LBD Glossary... "LMELBO"... (L)augh-(M)y-(E)lement-(L)oving-(B)utt-(O)ff... *bow*
The LBD Help Desk: (PC-users) To do the CENTS "˘" sign... Hold down the "ALT" key and then punch in "0162" on your 10-key pad (not the upper row of the keyboard!)... Just MY...!!!
The LBD D-I-Y Mods links:
LunchBoxDriver is offline   Reply With Quote Quick reply to this message
Old 05-28-2010, 11:38 AM   #4
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Good work on those links, Mrpolice. Mine had rusted threads too, and ate two Allen keys before I finally removed the nuts. I like the "hammer justice" idea.
Best to put some anti-seize or grease on the exposed threads of the new links, or paint as Mrpolice did, to avoid the rust problem in the future.
__________________
Old 08-18-2010, 05:51 PM   #5
SOCIAL DISTORTION
EOC Rank: Hydrogen
2003 4WD EX AT
Eternal Blue Pearl (EBP)
Send a message via ICQ to SOCIAL DISTORTION
Great pics....I am down south of you in Akron...howdy E neighbor. Did you remove your tires when you did this? This is a great site to help us with our E's
SOCIAL DISTORTION is offline   Reply With Quote Quick reply to this message
Old 08-19-2010, 08:45 AM   #6
mrpolice
EOC Rank: Hydrogen
2004 4WD EX AT
mrpolice's Avatar
Quote:
Yes I removed the tires - without doing that it would be a bigger pain than it already was. If you see LeBron down there kick him in the nuts.
__________________
Jon Miller
Cleveland, Ohio
Old 08-20-2010, 07:20 PM   #7
Retro Grouch
EOC Rank: Hydrogen
2003 4WD EX AT
Retro Grouch's Avatar
Thanks for the tutorial. I just bought a pair of those links. Weird thing though, they cost me $16 each side at a Toronto Honda dealership and they were even in stock, no waiting. Hope mine aren't seized and I plan to use graphite on the threads when installing. Since I'm reusing the old nuts, I'm going to include a couple of split washers to prevent them from backing out.
Retro Grouch is offline   Reply With Quote Quick reply to this message
Old 08-28-2010, 05:39 PM   #8
spdrcr5
Site Sponsor
2003 4WD EXS AT
Sunset Orange Pearl (SOP)
spdrcr5's Avatar
Send a message via AIM to spdrcr5
Added to the FAQ. Thanks! I am in the middle of doing this and will be using these instructions tomorrow to finish.
spdrcr5 is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 02:39 PM   #9
MME4me
EOC Rank: Helium
2005 4WD EX MT
Magnesium Metallic (MM)
MME4me's Avatar
mrpolice -- Are your new endlinks OEM or aftermarket?
If I go OEM, does anyone know if I'll need new Stabilizer Link Protectors? Or can the old ones be reused?
Confused over the price difference. Looks like the important part is only ten bucks and the plastic protector is sixty.
__________________
MODS
Honda: all season mats, splash gaurds, side steps (black), rear air deflector, fogs, cargo tray, cargo net, roof rack, locking gas cap, black front bumper garnish, black grille molding, black rear bumper garnish...
DIY: side marker->turn signal mod, manual AC defrost control mod, interior bike rack for two, GrilleGuy Black Razr lower grill insert (no zipties), cleared headlights, chrome painted sidemarker sockets...
Other: window tint, Thule snowboard rack, chrome bulbs...
MME4me is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 01:34 AM   #10
ziggie
EOC Rank: Oxygen
2004 4WD EXS AT
Nighthawk Black Pearl (NBP)
ziggie's Avatar
Great article Jon!!
I have a Q; how did you know they were bad..? did they have play or what?
MTIA
__________________
MTIA
Ziggie
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
ziggie is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Rear sway bar question? 2003OrangeBox Tires, Wheels and Suspensions 8 10-06-2015 09:50 AM
Replacing my own front Sway bar links daveybuoy Tires, Wheels and Suspensions 3 04-24-2010 10:08 PM
ST's Rear 1" Sway Bar: My Experience So Far junior marbles Under The Hood / Performance 5 10-11-2009 01:41 AM
Sway Bar End Links and Front Upper Strut Mount Replacement EG2E Maintenance and Service 10 06-11-2009 03:13 PM
ST Front & Rear Anti Sway Bar L-EH-MENT Under The Hood / Performance 6 07-31-2007 06:07 PM
