'03 Element Oil Consumption/Leak - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 09-11-2010, 06:57 PM   #1
AnOrangeLeeloo
EOC Rank: Hydrogen
2003 4WD EX AT
Sunset Orange Pearl (SOP)
Exclamation '03 Element Oil Consumption/Leak
Hello. I took my '03 evil toaster (as I call it) to my uncle's shop today, where I was told that it was dangerously low on oil. The mechanic who discovered that bit of fun news, said she couldn't find any discernable leakage.
A couple of months ago, the oil sensor burnt out, and the mechanic shop (who wasn't my uncle's, since I had to have it towed to the nearest shop & my uncle's was 20 miles away), who fixed that said that the oil was pretty darn low then too.
I've done numerous searches, trying to find if anyone else has had the same issue, but am unable to find anything. It only has 73 or 74 thousand miles, so it's not old enough to be this stupid yet.
Does anyone have any ideas what the cause might be? Is it burning oil (even though I've never seen any black smoke when I start the car in the morning) or is there an invisible oil leak in the belly of my evil toaster?
I've never seen any puddles underneath the car, except for the water from the a/c.
Thank you!
AnOrangeLeeloo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-11-2010, 09:59 PM   #2
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Kinda low mileage for an '03. Sometimes cars that sit a lot develop leaks. Check the oil level at least once a week to get a better handle on consumption. Watch the exhaust, especially on startup, for smoke. Also check the (cool) radiator for signs of oil contamination in the coolant.
__________________
Old 09-11-2010, 11:08 PM   #3
MikeQBF
Moderatorium
2008 4WD EX-P 6MT
Galaxy Gray Metallic (GG)
MikeQBF's Avatar
A faulty PCV valve can play games with oil consumption. These are more likely to foul on a vehicle that sees mostly frequent short trips and/or sits idle for long periods, as your low mileage would indicate. Easy, inexpensive fix, so don't be fretting about it just yet - get it checked, tho'.
MikeQBF is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 09:01 AM   #4
Bowzer
EOC Rank: Carbon
2008 4WD EX 5AT
Alabaster Silver Metallic (ASM)
Bowzer's Avatar
You mention no smoke (which can be hard to catch if not actually back there looking at it) but did you look at the tailpipe for any signs of an oily residue? This and the aforementioned coolant check for residue.
__________________
Member #23,382
238k Miles and Rolling
Lotsa Honda's...Lotsa miles
08 ASM EX AWD AT
Mods to Date: OEM Fogs, Home Depot Grill, Dual Dome Light Operation
Mods to Come: Assorted scratches, scuffs, and hidden french fries
Bowzer is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 03:34 AM   #5
markse
EOC Rank: Hydrogen
2007 4WD EX AT
markse's Avatar
JEEZ
I know it's one more thing to do in a usually ridiculously busy life but every one should check the oil every fuel fill up.
For me vehicles are expensive and I find it in my best interest to take care of them.
The hour of time it takes to check the oil for lets say 40 fill ups is a LOT cheaper than 3 or 4K for a engine. I don't make 3K an hour.
Sucks for me.
__________________
markse is offline   Reply With Quote Quick reply to this message
Old 10-24-2010, 05:30 PM   #6
AnOrangeLeeloo
EOC Rank: Hydrogen
2003 4WD EX AT
High Oil Consumption Question...and an odd clunking noise...
Took my E to my uncle (who owns his own shop) for an oil change and he said that the oil was dangerously low, and that i should monitor it closely to make sure I add oil when needed.
I just checked it today, and it was horribly low, so i added three quarts. My question is...it's an '03 70-thousand some miled vehicle, and what could be causing the high oil consumption? I had a genius (some dipstick I knew...not my uncle) replace my valve cover gaskets several months ago, and strangely enough the oil started disappearing...could it be related to him being a complete idiot and somehow screwing up the job? I see no discernable leaks, so I dont know what else to think.
Another thing is, now my car has a weird clunking noise coming from the rear right side whenever I'm going over minor bumps. Could that be something related to the ball bearings? I had some struts replaced by Honda not too long ago, so I don't think they would be acting up again. Thank you.
Old 10-24-2010, 05:53 PM   #7
protaganis
EOC Rank: Carbon
2003 4WD EX AT
protaganis's Avatar
Oil issue is most likely from head gasket replacement. See if you're leaving the telltale "Blueish Cloud" upon morning start-up. Also check for fresh puddles beneath engine. Take it to be fixed by your uncle. Never let the idiot who did it last time near your E again.
The clunk is harder to tell, Could be a strut, not sure. They have a limited lifespan that can vary depending on quality of unit and harshness of use.
__________________
Madness will take it's toll.
Please have exact change ready.
protaganis is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 01:54 PM   #8
AnOrangeLeeloo
EOC Rank: Hydrogen
2003 4WD EX AT
Exclamation Incorrect Installation of Valve Cover Gaskets...
hello, if the valve cover gaskets are installed incorrectly, could that lead to a lot of abnormal oil consumption? Several months after this installation my oil sensor blew, and I was wondering if the genius who did this job, somehow f-barred it (which according to my mechanic uncle is virtually impossible, but he didn't know this idiot), thereby causing the oil sensor to blow, and the abnormally high oil consumption?
If that is a possibly, what are the symptons? I do not see any oil leaks, or smoke coming out of the exhaust, nor anything else, besides the decrease in the oil level on the dipstick.
Thank you!
Old 10-25-2010, 02:42 PM   #9
Bowzer
EOC Rank: Carbon
2008 4WD EX 5AT
Bowzer's Avatar
THat oil has got to be going somewhere and fast it sounds like. Did you stand behind the car to detect the blue smoke? You'd be surprised how hard it is to catch a glimpse from the driver's seat of that kind of thing. Check the tailpipe to see if any oily residue is present. Also, while cold, check the engine coolant for milky looking contamination as is typical of oil contamination getting to the coolant.
Can't comment on the oil sensor question I'm afraid. But it may be good to just get you car to your uncle for a more thorough check with the oil finding its way out so quickly.
Best of luck!
__________________
Member #23,382
08 ASM EX AWD AT
Old 10-25-2010, 05:01 PM   #10
speeder
EOC Rank: Hydrogen
2005 2WD DX MT
I have 105 000 miles on my E and the engine is burning 1 liter every 3000-4000 miles....
speeder is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
oil leak sydneyrules Problems & Issues 4 01-08-2009 08:22 PM
motor oil consumption? dohcvtec Maintenance and Service 7 04-27-2007 12:21 PM
Oil Consumption ElementNML Problems & Issues 5 03-05-2007 03:16 PM
Oil Consumption seakayaker Maintenance and Service 30 01-16-2007 07:46 PM
Oil leak after Wal-Mart oil change. ocho9 Under The Hood / Performance 33 08-14-2005 03:38 PM
