Ignition key/lock problem - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 04-08-2011, 12:53 PM   #1
NMIELEMENT
EOC Rank: Hydrogen
2005 2WD EX MT
My key wouldn't turn in my element ignition. replaced complete ignition. now car will not start. HELLLLLPPPPPP!!!
NMIELEMENT is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-08-2011, 01:02 PM   #2
lizzurd
Moderator Eh?
2006 4WD EX-P AT
Neutron Blue Metallic (NBM)
lizzurd's Avatar
Quote:
The ignition switch has an immoblizer unit attached to it that needs to be reprogrammed to your keys.
You will need to get it to a dealer for programming.
lizzurd is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 10:26 PM   #3
Rob Dobbs
EOC Rank: Carbon
2007 SC 2WD 5AT
Nighthawk Black Pearl (NBP)
Not sure if this will work on the E but ive had luck with it when moving vehicles with replaced ignitions before. Tape the old key onto the new key so the end is as close as possible to the steering column. The transponder signal needs to be read to start the vehicle.
Rob Dobbs is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 10:31 PM   #4
lizzurd
Moderator Eh?
2006 4WD EX-P AT
lizzurd's Avatar
Quote:
It wont work. The code stored in the key has to match the code in the immobilizer unit (receiver) mounted on the ignition switch. A new unit will not have a code stored in it.
Other than towing it to a dealer for programming the only option is to swap the old immobilizer unit onto the new ignition switch.
Old 12-01-2011, 07:23 PM   #5
nembamike
EOC Rank: Hydrogen
2006 4WD EX-P AT
Alabaster Silver Metallic (ASM)
nembamike's Avatar
My 03 element is having the same problem and needs the ignition, key and immobilizer assy replaced. Deler quoted me around $600 to replace and reprogram. Currently leaving spare key in the ignition all the time which works but nervous about that. Does anyone know the part number or part numbers of what needs to be replaced? I thought of trying salvage yards but want to make sure I get everything I need before taking it to the dealer to do the install. Thanks.
nembamike is offline   Reply With Quote Quick reply to this message
Old 12-02-2011, 09:05 AM   #6
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Quote:
Originally Posted by nembamike View Post
...salvage yards but want to make sure I get everything I need before taking it to the dealer to do the install
Your dealer will install owner-supplied used parts?
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
immobilizer problem without key even near ignition switch! Elementery Problems & Issues 147 03-03-2017 03:02 PM
ignition lock cylinder DCIVW Maintenance and Service 10 12-26-2011 03:41 PM
Problem with key not turning in ignition bonadrag14 Problems & Issues 2 05-16-2009 03:36 PM
Problem with door key lock skuba Problems & Issues 3 12-17-2007 06:04 PM
ignition key brabf Miscellaneous / General Element Discussions 1 09-08-2005 02:09 PM
