Testing a Bad AC Condenser Fan - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 07-03-2011, 09:44 AM   #1
andyf80
EOC Rank: Helium
2003 2WD LX AT
Shoreline Mist Metallic (SMM)
andyf80's Avatar
Hi guys/gals,
I wanted to tell you what I expereienced and my steps for diagnosing a bad fan. (Radiator or AC Compresser fan).
The symptoms I experienced were:
  • Hotter than normal engine temps
  • AC not functioning as well at idle
  • AC compresser clicking when cycling on/off (clicking stopped when AC was off)
  • AC condenser fan not spinning while engine was hot and AC on
The fan in my mind was immediately suspect, but I had not noticed it until i'd left it at idle for 45min+ while at the carwash. Looking back however, I did notice similar symptoms while sitting in traffic etc.
I wanted to rule out a bad fan before checking fuses/relays/connections etc.
Here's how you verify your fan's operation:
(with your engine OFF)
  1. disconnect electrical connector to the AC Fan
  2. connect a wire from the positive (+) side of the battery to terminal #2 (an in line fuse on your test wire is recommended)
  3. connect a wire from #1 terminal to ground (-)
  4. If the motor fails to run or does not run smoothly - it's faulty
The ground/negative (#1) side of the connector is a black wire & positive
(#2) is a blue wire.
In my case, the fan was at fault.
One question it did bring up was:
I expereienced a clicking sound when the AC Compressor would cycle on/off...
Is there a cut-off switch if the system is running too hot?
andyf80 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-03-2011, 11:53 AM   #2
Wrenchmeister
EOC Rank: Oxygen
2006 2WD EX-P AT
Tango Red Pearl (TRP)
There is a switch at the high pressure side that cuts-off the compressor when the pressure is too high. (not based on temperature, but works with the temperature as consequence)
which motor did you change? the pan-shaped or the long one?.
Wrenchmeister is offline   Reply With Quote Quick reply to this message
Old 07-03-2011, 12:12 PM   #3
andyf80
EOC Rank: Helium
2003 2WD LX AT
andyf80's Avatar
I have not changed it yet - it's on order, but it's the shorter one - ac condensor fan (on the passenger side).
The motor itself goes for $40-50 but I picked up the whole assembly for $60 shipped so decided to go that route.
Thanks for the confirmation Wrench - I figured it was some type of cut-off as it stopped this symptom after I got the car moving and some cool(er) air across the condenser.
Old 07-14-2011, 06:19 PM   #4
fireftr45
EOC Rank: Hydrogen
2004 4WD EX AT
Had exactly the same problem where the fan motor went bad and it caused my AC to cycle on and off on over pressure.
Unfortunately I was pressed for time and took it to an AC guy in Pensacola that replaced the fan to the tune of $240 for the fan and 175 for labor. A week later I found out I could have gotten the fan motor for $63 and done it myself.
I believe a person should benefit from their labor. But there's a special place reserved for all the mechanics who screw people over...
Will ensure I look here on the site before I ever shell out another dime for someone to work on my E.
Erik
fireftr45 is offline   Reply With Quote Quick reply to this message
Old 07-14-2011, 07:48 PM   #5
psschmied
EOC Rank: Neon
2008 4WD EX 5AT
psschmied's Avatar
It isn't rocket science to test an electrically-isolated 12VDC motor with a 2 pin plug, but it sure can be aggravating to get to that plug. Actually doing step 1 can be a b*tch.
The key to identifying which of the fans involved isn't functioning, is simply to see if the Element overheats with the AC off. The condenser fan shouldn't be functioning; the radiator fan should be on as soon as the engine warms up.
The two fans are electrically interchangeable, so if you are in a jam and the radiator fan fails you have a spare. Just unplug both, and if the radiator fan plug won't reach, run jumpers over to the condenser fan.
Aside from the thermostatic switch, the other electrical components involved in fans' operation are listed in this thread: http://www.elementownersclub.com/for...270#post922270
psschmied is offline   Reply With Quote Quick reply to this message
Old 07-14-2011, 09:40 PM   #6
Wrenchmeister
EOC Rank: Oxygen
2006 2WD EX-P AT
I have a better way... Just get into the Hwy and the clicking will go away and the AC will work great...
Old 07-15-2011, 09:18 AM   #7
psschmied
EOC Rank: Neon
2008 4WD EX 5AT
psschmied's Avatar
Quote:
You've thinking of those creatures in cars, with their heads out the window and tongues flapping in the wind. They don't sweat; panting is how they cool off. They come in all breeds, but when you hear them howling nut-ty things, you can tell that they're Wrench-meisters.
I don't suggest that an overheating car be troubleshot by driving it; idling while parked should work.
Old 07-16-2011, 05:53 AM   #8
preston
EOC Rank: Hydrogen
2003 4WD EX AT
Alabaster Silver Metallic (ASM)
Yes check fan
This is a very common problem with the E AC fan and Engine fan,, A friend/mechanic showed me a trick if your e is running hotter than normal and it seems that one or both fans should be turing on give them a tap with a wrench or hammer on the back of the fan motor(while the engine is running). Both my fans went out and it wasn't until my second fan stopped working that I figured out I had a problem. Initially I though I had an AC problem, but sure enough when my engine started heating up I kept it running tapped the fan and it began to working. I have replaced both my fans and it takes about 45 mins engine fan and 15 for the AC fan, the hardest part is getting the plastic wire clips re connected after the new fan is seated in place. See other posts on fan replacements.
preston is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 07:10 AM   #9
Wrenchmeister
EOC Rank: Oxygen
2006 2WD EX-P AT
Of course if your car is overheating.
that might indicate a different problem and a different approach needs to be taken. I wouldn´t take it for a spin either.
( I didn´t really get the dogs comment. was that a joke? )
Old 07-19-2011, 06:57 AM   #10
E_Causatum
EOC Rank: Helium
2005 4WD EX AT
Satin Silver Metallic (SSM)
Agree with other posters. I recently change my honda accord's passenger fan and radiator. Car overheated while parking for 25 min. Only one of my fans was working. I would like to add that both fans turn on and off when you turn your AC on. If you see that one fan is not working with your AC on and the other is working, that is a very good sign that the nonworking fan is broke. You can get one from a slavage shop for $50-70 for the whole fan assembly - will cost around $160 from auto parts store for a new fan assembly and cost more if you buy a genuine honda part. I opted for just replacing the fan motor with a new one fron autozone for $100. If you have to buy the motor, make sure you check brand of the radiator. It can be Valeo or Denzo and the motor they use is totally different. BTW, most overheating issues usually occurs when you're in idling for prolonged period of time. Check for leaks and coolant level too.
Also check your thermostat if it is stuck. I use FailSafe brand thermostat. Even if the thermostat is broke, it keeps the flow of coolant continueously.
E_Causatum is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
A/C Condenser Crashman Problems & Issues 1 02-25-2009 09:43 AM
Condenser Replacement clarkey Maintenance and Service 0 07-13-2008 02:52 PM
AC Condenser replacement? elementDAB Do-It-Yourself / Mods 9 04-27-2008 01:27 PM
A/c Condenser Damaged SOXFAN Problems & Issues 24 08-01-2006 07:04 AM
A/C Condenser Problems anyone??? momome Problems & Issues 7 10-30-2003 08:54 AM
