Isolating battery drain issue - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 09-03-2011, 06:12 PM   #1
minnElement
EOC Rank: Hydrogen
2003 2WD EX AT
The battery on my 2003 Element has been inexplicably draining if left sitting for more than overnight to the point where it almost can't turn over the engine. I've traced this to the "Back Up" circuit through the fuse box, but I have no idea what that is and what exactly could be the issue.
Ideas?
minnElement is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-03-2011, 08:01 PM   #2
Rob Dobbs
EOC Rank: Carbon
2007 SC 2WD 5AT
Nighthawk Black Pearl (NBP)
Interesting as Ive just discovered this on my 07. At first I suspected a ground or other issue from the custom stereo install but all that is not the issue.
Rob Dobbs is offline   Reply With Quote Quick reply to this message
Old 09-04-2011, 08:06 AM   #3
minnElement
EOC Rank: Hydrogen
2003 2WD EX AT
I have a stock radio. The only drain should really be come from the little flashing anti-theft light when the car is off, but certainly it shouldn't kill the battery in that short period of time.
I've had the new battery tested and it's good. Hmmmm.
Old 09-04-2011, 06:31 PM   #4
Rob Dobbs
EOC Rank: Carbon
2007 SC 2WD 5AT
Im hoping to get mine one the rack this week to check all grounds and leads. I did notice corrosion on the negative terminal so I wonder if there may be some on the alternator leads.
Old 09-06-2011, 09:58 AM   #5
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Do you have an aftermarket trailer hitch?
__________________
Old 09-06-2011, 07:31 PM   #6
ApriliaGuy
EOC Rank: Iron
2004 4WD EXS AT
ApriliaGuy's Avatar
or any trailer wiring harness or patched in connection for trailer/aux lights?
__________________
"It ain't easy bein' cheesy"
ApriliaGuy is offline   Reply With Quote Quick reply to this message
Old 10-25-2011, 06:43 PM   #7
Rob Dobbs
EOC Rank: Carbon
2007 SC 2WD 5AT
Turns out mine was a bad Optima red top. No hassle on the return though.
Old 03-09-2012, 08:21 AM   #8
Sailor Tom
EOC Rank: Hydrogen
2003 4WD EX AT
Satin Silver Metallic (SSM)
This thread describes my problem with my 2003. I am having the same problem, brand new battery drains if the cars sits any length of time (brand new alternator also). I do have a trailor light connection that I plugged into the wiring harness 4 years ago. It was not a Honda part, but came from a reputable supplier. Would appreciate any suggestions in tracking down my problem.
Sailor Tom is offline   Reply With Quote Quick reply to this message
Old 03-09-2012, 01:16 PM   #9
ramblerdan
2004 4WD EXS MT
ramblerdan's Avatar
One method: Set the dome light to the off position. Make sure you have your radio code ready, and be prepared to reset your driver's window. Disconnect the negative terminal from the battery and put a VOM, set to milliAmperes (mA), between the battery post and terminal. Pull the fuse for the radio (to take the tiny draw for the clock and radio code memory out of the mix), noting where it has to go back later. Then pull the other fuses one at a time while a helper watches the meter. If pulling a fuse causes the reading to drop, you have a good place to start in finding the parasitic draw. Remember that you have two fuse boxes, one under the dash and another under the hood.
__________________
Old 03-09-2012, 01:42 PM   #10
Sailor Tom
EOC Rank: Hydrogen
2003 4WD EX AT
Thanks for the tip. I found a posting on another site that recommended changing the a/c compressor clutch relay. I replaced that and the condenser fan relay (7.00 each at dealer). I will do the voltmeter check also. Will report back.
Sponsored Links
Advertisement
Reply
Tags
battery charge , electrical
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
P0685 ECM issue due to bad battery??? [beetlegeuse] Problems & Issues 3 09-03-2013 10:36 PM
Will I drain my battery? tyneldad Miscellaneous / General Element Discussions 2 07-10-2010 05:18 PM
12 power-outlet fan - run overnight w/o battery drain? orome Interior 9 04-11-2005 11:47 AM
Portable Fan/Battery Drain music&dogs Mobile Electronics 3 05-10-2004 06:57 AM
Battery Drain and Silencer Alarm bhutch Problems & Issues 0 12-26-2003 01:54 PM
