it may help to know the name. the front bushing is called the compliance bushing.
are you planing on doing this job yourself? unless you have the specialized tools you will need to remove the entire arm which includes dealing with the ball joint. again easy if you have the special tools.
it will then need to be pressed out and new pressed in.
from what ive heard. most honda techs can swap compliance bushings or ball joints with the arm still in the car. due to specialized tools just for that
anyway heres the part number. 51391-SCV-A03 they should be around 20$ each.
04513-SCV-000 is the service kit includes the pair around 40$(no diff from buying 2 of above)
you can also get the whole arm complete with new bushings already installed for like 120$ each.
51350-SCV-A03 right
51360-SCV-A03 left
just some thought. swapping complete arms yourself may be cheaper then the complete job at a shop and in the end you have all new parts and the compliance bushing is pre aligned by the factory.
ive seen all too many shops give back misaligned compliance bushings. or their replacement spherical bushings.
