Should I install a new intake manifold gasket when I reinstall the intake manifold? - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Maintenance and Service
Notices
Reply
Thread Tools Display Modes
Old 03-16-2013, 07:56 PM   #1
nbx00
EOC Rank: Hydrogen
2004 2WD EX AT
Satin Silver Metallic (SSM)
I am changing out the starter on a 2003 honda element. The starter is under the intake manifold so I have to remove the intake manifold.
Should I install a new intake manifold gasket when I reinstall the intake manifold or can I reuse the old intake manifold gasket?
I would appreciate advice from a technician.
nbx00 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-17-2013, 09:17 AM   #2
motoracer47
EOC Rank: Helium
2004 4WD EX AT
You might be able to remove the starter from underneath the car, thereby not removing the intake manifold. It will be a tight fit, but it looks possible. If you do remove the lower (outer) intake manifold, yes, definitely get a new gasket. You can get a FelPro intake manifold gasket kit for $15 from Autozone. It has the gasket you will need, plus the gasket for where the manifold connects to the head. Autozone (at least mine) only carried the kit with both, but for 15 I didn't care.
Check this thread, there is a discussion on the various ways to do it. On the second page, I put up a video of the clearance around the starter. In my video, I removed the manifold and went in through the top. Might help you decide if you want to try it from the bottom.
http://www.elementownersclub.com/for...174&highlight=
motoracer47 is offline   Reply With Quote Quick reply to this message
Old 03-24-2013, 02:08 AM   #3
ajchien
EOC Rank: Helium
I am not a technician, but I was advised by a Honda dealership technician that the intake manifold gasket was simply a centering guide, and did not need to be replaced. Is that close enough to staying at a holiday inn?
__________________
2003 Honda Element EX 2WD, Eternal Blue 153k+ mi
2003 Honda CR-V EX AWD, Mohave Mist 190k+ mi
ajchien is offline   Reply With Quote Quick reply to this message
Old 03-24-2013, 09:16 AM   #4
Wrenchmeister
EOC Rank: Oxygen
2006 2WD EX-P AT
Tango Red Pearl (TRP)
Centering guide? That's off...
Changing the gasket is the right way. Can you get away without changing it? Maybe. Does it make sense trying to save the old gasket? Up to you...
Wrenchmeister is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Intake Manifold Copper Coat Gasket or not? diverdon Problems & Issues 4 10-04-2012 09:24 PM
rtb intake manifold same as cr-v? Mo'03 Under The Hood / Performance 2 03-07-2010 03:42 PM
FS:raa intake manifold xxicerocaxx Trading Post 0 02-20-2010 12:13 PM
hondata intake manifold gasket xxicerocaxx Under The Hood / Performance 8 02-15-2010 02:21 PM
Quick- Hondata intake manifold gasket - Worth it? Yes/no? hooptey Under The Hood / Performance 4 11-18-2009 12:57 PM
