Honda Element Vibration - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 09-22-2013, 04:57 PM   #1
von.brokenzipper
EOC Rank: Hydrogen
2003 4WD EX AT
Crystal Black Pearl (CBP)
Smile Honda Element Vibration
First of all I apologize if this is topic was covered in the past but after reviewing several topic, I dont see a "match" to the issue I have not.
I have 03 Element EX AWD and I feel heavy vibration when I accelerate regardless the speed but I can feel it stronger on slow speed/when just start riving it from 0-40mph.
As soon as I press the pedal and the car pull the weight of the car, I can feel it vibrate but as soon I took my feet of the pedal, the wiggle is gone. So, I don't think the issue is with the tires of brakes. During the drive when I didn't pull the car (station) I don't feel anything but as soon as I press the pedal the car start vibrate again and mostly in the front end.
Could that be axle or drive shaft ?
Please advise....I need to figure this out without doing too much "try and error"
Thank you so very much for all advise and inputs !
von.brokenzipper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-22-2013, 07:17 PM   #2
Rick92040
EOC Rank: Carbon
2008 2WD EX AT
Kiwi Metallic (KM)
grab the axle and see if it wiggles. If it does it's bad Some have reported vibrations that were never cured.
Rick92040 is offline   Reply With Quote Quick reply to this message
Old 09-22-2013, 07:26 PM   #3
von.brokenzipper
EOC Rank: Hydrogen
2003 4WD EX AT
Rick,
I guess you are referring to the front axle right ?
how should i do that ? just lift the car and wiggle the axle ?
thanks again!
Old 09-22-2013, 07:29 PM   #4
GeekAndDestroy
EOC Rank: Hydrogen
2004 4WD EX AT
Satin Silver Metallic (SSM)
Quote:
Just that. You might be able to do it on the ground. Also check your engine and transmission mounts.
GeekAndDestroy is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 09:59 AM   #5
Mott Power
EOC Rank: Oxygen
2003 4WD EX AT
Eternal Blue Pearl (EBP)
Check engine, transmission, and rear differential mounts - those are the most prominent sources of vibration under acceleration since they are designed to absorb any stress of the engine to the chassis. Check to see if they are dry rotted, cracking, etc. A bad axle would cause the vibration no matter what the speed since they are constantly rotating, it wouldn't depend much on engine load. All axles will have some play as well, so don't assume the axle is bad if you can slightly wiggle it. Chances are it's a drivetrain mount.
Mott Power is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 10:07 AM   #6
blacklabel
EOC Rank: Helium
2007 2WD LX MT
Atomic Blue Metallic (ABM)
blacklabel's Avatar
is there an allowable amount of wiggle? I am able to move my own ~1-1.5mm (left/driver side axle)
blacklabel is offline   Reply With Quote Quick reply to this message
Old 10-22-2013, 09:03 AM   #7
zvovchik
EOC Rank: Hydrogen
2004 4WD EX AT
Sunset Orange Pearl (SOP)
help! same problem
I have 2004 element AWD and excactly the same vibration issue described. I have changed all the engine mounts. 4 total. Have new michelin defender tires, new brake rotors/pads. And the vibration is still there. blacklabel have you fixed your issue?
zvovchik is offline   Reply With Quote Quick reply to this message
Old 10-22-2013, 09:15 AM   #8
Mott Power
EOC Rank: Oxygen
2003 4WD EX AT
Quote:
Check your differential mounts - the vibration might also increase when driving up an incline if it's the rear diff mounts. This is all really trouble shooting, vibrations can be caused by numerous issues but they are most commonly caused by drivetrain mounts in cases where you feel it only when rpm's and engine load are applied. If it's with the actually components, like axles or driveshaft, they usually occur constantly and increase with speed but can also be more noticeable as engine load is applied (via your foot).
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Element has vibration dom08 Maintenance and Service 9 09-17-2013 09:05 AM
2003 Element Rumble Strip Type Vibration rider93hawg Problems & Issues 55 11-14-2009 09:09 PM
FS: 2003 Honda Element EX 84K miles w/lots of honda accessories (Denver,CO) Berg Trading Post 5 12-15-2008 05:33 PM
Rubbing Noise and Vibration from Rear of Element jdcashwell Problems & Issues 15 09-21-2007 01:11 AM
Honda Tuning Mag: 2004 Honda Element-D - Out of its Element [5.7] T Mac Miscellaneous / General Element Discussions 0 05-25-2007 08:31 PM
