rear wheel bearing, easier replacement - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Accessories, Care and Mods > Tires, Wheels and Suspensions
Notices
Reply
Thread Tools Display Modes
Old 01-29-2015, 10:25 AM   #1
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
Tangerine Metallic (TM)
Thought I would share the info I found out for myself. I have a bad right rear wheel bearing and for my 07' EX AWD it was $160 for aftermarket, $170 for OEM and the kicker was that ordering the whole RR knuckle(from Honda) was $140 (loaded with new bearing and bushings). Which means less work and more parts replaced at an awesome price. At that price I might just do the left side as well
Hope that helps someone
Kamn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-29-2015, 12:36 PM   #2
ramblerdan
EOC Rank: Crankypants
2004 4WD EXS MT
Fiji Blue Pearl (FBP)
ramblerdan's Avatar
Thanks, Kamn.
__________________
Old 01-29-2015, 01:31 PM   #3
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
no problem,
I just ordered the left side as well and it was 10 bucks cheaper for some reason
now to get some adjustable rear upper control arms
Old 01-30-2015, 11:24 AM   #4
JoeBaker
EOC Rank: Helium
2005 2WD LX MT
Crystal Black Pearl (CBP)
JoeBaker's Avatar
Is this the Part?
552215-SCV-A50 Knuckle, L. RR. USA 1 $204.77 $147.43
Is it really loaded with the bearing?, if yes, amazing deal
JoeBaker is offline   Reply With Quote Quick reply to this message
Old 01-30-2015, 12:30 PM   #5
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
The dealer called me this morning to say everything has arrived and I asked him to open the box and look inside and tell me if the bearings are really there along with the bushings AND apparently its a YES. Sweet, the hardest work will be seized bolts and pulling the hub out.......press in new hub, and bolt it back in
I dont understand it personally but I also don't care, as long as its less work and less money
Old 01-31-2015, 08:19 PM   #6
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
SO, to update this and stop anyone from getting the knuckle..........the meathead in the parts department was a little turd and lied to me on the phone when i asked him "can you open the box and tell me that you see a bearing attached to the knuckle?".......his answer was yes. Until today when I went to get the parts and opened a box that was stapled shut (so no one opened and checked".....sure enough there was no bearing, But the manager was super cool and gave me 20%-30% off all the parts I ordered.
SO THERE IS NO BEARING ATTACHED TO THE KNUCKLE, but there are bushing stuffed in it already
SOrry dudes
Old 01-31-2015, 10:50 PM   #7
JoeBaker
EOC Rank: Helium
2005 2WD LX MT
JoeBaker's Avatar
still an amazing deal
I did a youtube video on reassembling the knuckle with bearing, hub and dust plate, check it out
http://youtu.be/OjZdYWPW8CU
Old 02-01-2015, 08:05 AM   #8
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
Good work in the video, it was nice to see you make your own tools to press the bushings in the knuckle and getting the hub back in. I am a retired Automotive tech and I have seen licensed techs do a butcher job with all the right tools around them and here you are at home doing a good job.........nice
Was the backing plate and parking brake parts all from Honda or aftermarket??
My right rear backing plate is getting chewed up from the rotor when i make turns which is what has led me to replacing the wheel bearing, and since I was there i might as well do the all the bushings
Old 02-01-2015, 08:07 AM   #9
Kamn
EOC Rank: Helium
2007 4WD EX 5AT
And when I say "retired", I am not retired by age but left the industry because I got sick of working around hacks and the constant competition to make a buck
Old 02-01-2015, 10:54 PM   #10
JoeBaker
EOC Rank: Helium
2005 2WD LX MT
JoeBaker's Avatar
Quote:
The backing plate and parking brake bracket that bolt on the plate are OEM, the parking brake and hardware kit are aftermarket.
$20 something for the backing plate and close to $40 for the parking brake bracket that attach to it.
The previous owner had some repair done on that rear wheel due to overheat.
They used a undersize Honda civic backing plate, the whole parking brake assembly was almost pulverize by rust and dirt...real hack job.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Rear wheel bearing replacement wboob Maintenance and Service 27 12-15-2014 09:09 AM
Rear Wheel Bearing Problems JakeSpec Problems & Issues 0 07-09-2008 03:52 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
