Can pull key out while gear in Neutral - Honda Element Owners Club Forum
Go Back   Honda Element Owners Club Forum > Honda Element > Problems & Issues
Notices
Reply
Thread Tools Display Modes
Old 07-13-2016, 06:54 PM   #1
wmj259
EOC Rank: Helium
2003 4WD DX AT
Royal Blue Pearl (RBP)
Hello,
So my little brother had a incident where he thought he put the Element in the park and somehow managed to remove the key. Long story short, Element reversed down small hill and hit my other car. No damage (visually, and structurally other car had shock absorbs on the bumper support.
Anywho, noone believe him so we all went with our life, I am starting to believe him now.
Last few days I had starting issues. I would turn the key and it would sound like somethings sparking inside the steering wheel itself. I would hear some crackling/lightning sounds, sometimes it would start right up other times I would hear the sound and then it would start up. Sometimes I would while holding the brakes put the car in Neutral and it would do the above and then it starts up.
However, recently I noticed today when I was in neutral I for some reason thought of pulling the key out..................key came out..............
I heard odysseys had this problem.
wmj259 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-13-2016, 10:28 PM   #2
Bill Berckman
EOC Rank: Oxygen
2007 4WD EX MT
Galaxy Gray Metallic (GG)
Bill Berckman's Avatar
Could just be the ignition key switch is worn out. You could pull the key out of my old 85 Cevy Cavalier while you were driving. Never did get that fixed as it worked otherwise as it was supposed to.
__________________
Bill Berckman
2007 Element EX AWD 5MT
Bill Berckman is offline   Reply With Quote Quick reply to this message
Old 07-14-2016, 08:03 AM   #3
wmj259
EOC Rank: Helium
2003 4WD DX AT
Quote:
But is the starting the car an issue with the ignition also?
Is it the whole switch that's gone bad or can I do the wafer replacement (similar to door locks)?
Old 07-16-2016, 11:33 AM   #4
wmj259
EOC Rank: Helium
2003 4WD DX AT
Well as to the problem where I have to literally turn the key till it almost breaks to start the car, or sometimes i hear a click as the start barely gets the voltage. sound like if you touch the leads of a batter kind of click. Could be the ignition switch/cylinder?
Old 07-16-2016, 11:58 AM   #5
Marv
EOC Rank: Oxygen
2005 4WD EX AT
Magnesium Metallic (MM)
Sounds like two problems, both ignition switch related. The bzzt noise from the steering column and certain key action rqd. to start is most probably covered in this thread https://www.elementownersclub.com/for...ad.php?t=65155. The part is cheap and fairly easy to replace. The key coming out in neutral sounds like an actual ignition lock/cylinder/wafer problem. Neither cheap nor easy alas. If a locksmith/dealer were doing it, they almost would replace both as a complete assembly. $$
Marv is offline   Reply With Quote Quick reply to this message
Old 07-16-2016, 02:04 PM   #6
wmj259
EOC Rank: Helium
2003 4WD DX AT
I can change the steering switch myself, will cost around 50 some bucks. The ignition cylinder lock, can I change the wafers in it?
Old 07-18-2016, 04:28 PM   #7
nacranym
EOC Rank: Neon
2004 2WD EXS 6MT
don't know your skill level, but the mechanical and the electrical parts of the ignition switch are separable and the mechanical parts respond to usual locksmith type skills, such as replacing wafers.
__________________
Ordinary Old Member of:
nacranym is offline   Reply With Quote Quick reply to this message
Old 07-18-2016, 06:23 PM   #8
Marv
EOC Rank: Oxygen
2005 4WD EX AT
Here is a walkthrough from the resident expert to give a general idea of what's involved if you haven't seen it already https://www.elementownersclub.com/for...507#post962507
Old 07-18-2016, 10:32 PM   #9
wmj259
EOC Rank: Helium
2003 4WD DX AT
Well I did the driver door lock fix, except I took it to the locksmith thats literally like 2 blocks away.
I saw that one of the wires for the door lock mechanism was not even in the connector. The metal contact for the wire isnt even on it. So it was just hanging there, that proves my driver door not responding to the key remote. Thankfully the door sensor open/close was fine.
I am having troubles with the door open/lock button. When I had the door panel off it would work but after plugging it in, the open button works while the lock one doesn't.
Old 07-21-2016, 06:24 PM   #10
hotelement
EOC Rank: Hydrogen
2003 4WD EX AT
hotelement's Avatar
I believe there was a recall that fixes this. Check your TSB.
hotelement is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your E?
Model
What model is your E?
Color
What color is your E?
Can you spell?
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replaced Clutch, Now car won't roll in neutral (or in gear) cursh Maintenance and Service 10 04-27-2015 12:23 AM
2003 EX Stalling when in neutral 4dadogs Problems & Issues 6 08-30-2012 09:29 AM
Cheapskate camping gear- sleeping gear madkins007 Bikin', Campin', Hikin', and Kayakin' 0 11-01-2011 09:50 PM
gear shift knocked into neutral while driving!?! bisco Problems & Issues 21 09-14-2006 01:13 PM
To neutral or not to neutral texastoaster Ask The Dealer 9 06-21-2006 08:09 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
