1 - 2 of 2 Posts
So here's what happened. I bought a power inverter and hooked it up to my front accessory socket, and it popped the 10 amp fuse under the drivers dash. I changed that. Then I tried to start my car and nothing happened. I know the battery is good and tested it on a multimeter. Getting 12 volts there. I pulled out the starter and tested it and it starts right up. The starter is good. I use my multimeter and tested fuse number one in the under dash box and it is getting 12 volts. All the accessories turn on, lights, blower fan, etc. The ignition relay fuse, the square black one is not getting any power though. I tested it and the fuse itself is fine. Any ideas about what could be in line that is preventing my car from powering the starter up?
1 - 2 of 2 Posts
