Hi All,
Does anyone have an 08 Element SC Fog Light bracket they'd be willing to sell or share with me so I can make a copy and 3D print it?
I want to put the OE fogs in, but the OE kit isn't available. The lights themselves are the same as in the 06 Acura MDX and I have a brand new set, but I need the brackets to make em work.
Brackets look like this.....
https://www.dropbox.com/s/ecqq7cbjctd91b1/sc-fog-bracket.png?dl=0
Any help would be awesome.
Cheers
Rob
I'd also be very interested in getting these printed up and have access to a laser scanner if that would help. Think you could print some bumper spoiler caps if we were able to source some to make a 3d model? what about rear deflectors/spoilers?
Here is a fairly simple alternative mounting bracket I cut from some 1/4 inch clear acrylic from Menards home store. I cut out the opening with a jig saw. Acrylic is a little brittle so any number of other materials would work also. The bracket will slide into the fog light then sit down onto the flat part of the fog light. A simple metal bent "L" will hold the fog light down to the other side of the acrylic.
202822
202825
Hi All,
Dropbox - Link not found
Cheers
Rob
I've got a flat version made from HDPE and aluminum that work great.
