1 - 10 of 10 Posts
I had my new Kumho Solus KR21 (235/60/17) put on a couple weeks ago. I had a vibration in the car so I took it back to get em rebalanced. He said he'd do the front first since you can usually feel a vibration in the front the most. So he rebalanced but they weren't off too much. Went out on the highway and still a vibration. Took it back in and the rear drivers side was off by 1 GRAM!!! That's like a paper clip!! I couldn't believe that that small of an amount could throw the tire off so much. He said 1/2 gram would cause a vibration and 2 Grams would feel like your tire is about to fall off. So if you feel a vibration check for a screw or nail or something stuck in the tire since that could throw off the weight enough to vibrate!
Just thought I'd throw that out there.
All of the pebbles that get picked up in the tire tread would constantly throw your balance off.
I do remember taping a d-cell battery to the inside of someones wheel before to get back at them for something.;-) That really shook the heck out of that car.
I dunno he said gram several times. Maybe he did mean an ounce. I dunno. Either way it doesn't take much to throw it off.
Discussion Starter · #7 ·
Or he could've said "dram" which about an eighth of an ounce. We run in to those sometimes but I can't imagine a dram causing a balance problem unless he was talking about a dram of pot.
Hey! Does anyone still use lead wheel weights? I just happened to notice that the weights on my E look like little plastic housings with who knows what inside. I guess I'm either getting behind the times or all the scrap lead I've been collecting over the years ought to be worth something sooner or later.
1 - 10 of 10 Posts
