Engine oil and filter - replace
Fluid levels - top off all
Lube hinges, locks, latches, and hood cable
Front / Rear brakes - visual inspection
Transmission fluid - drain & refill
Clutch - adjust if applicable
Battery posts - inspect & clean
Fuel lines, tank, lines & connections - inspect
Suspension mounting bolts - inspect
Tires - balance rear tires and rotate to front; adjust pressure & inspect tire wear pattern
Coolant system - Check level & test protection
Wiper blades - check operation & wear
Park brake - adjust & lube as needed
Front/Rear disc calipers & hoses
Air filter - inspect
Exhaust system - inspect
Power steering system, gearbox, and axle boots - inspect
Adjust valve clearance if applicable
Spark plugs - replace (except platinum plugs)
Suspension, struts & steering - inspect
Brake Fluid - replace and bleed system
15,000/45,000/105,000 - additional cost for cooling system service
Engine timing belt and accessory belts
