1 - 20 of 41 Posts
I want my E to source ambient temp air vs. the hot air under the hood. I studied the drawings of the intake system, and realized how easy this would be.
1). Take off the intake resonator. This involves removing the two 10mm bolts, clearly visible, that hold it to the driver's side inner fender. Also temporarily take off the negative chassis ground (goes from neg battery post to driver's inner fender, also 10mm). Take off battery hold down clamps and move battery forwards and parallel to the radiator.
2). Remove the 10mm bolt that holds the electrical box (directly above where the resonator sits) to the fender so you can just ease this up and out of the way.
3). Remove the rubber hose between the resonator and the air filter box. It just pops off. Lift out the resonator, working it out between the battery, fender and power box.
3). Reinstall battery clamps and ground strap. Reinstall the bolt for the power box.
I then went to AutoZone and got auto intake hose, 3" id, part # P319-325. It's about 2.5 - 3' long. It slips over the inlet to the air cleaner box, then can be routed over into the driver's side fender well through the large hole where the resonator used to sit. It has little snap clips on both ends, so you can secure it to the filter box. I will probably go back with some zip ties and secure the end of the hose in the fender.
Hose cost: $11.99 and labor time of about 15 minutes.
Result: You will hear a bit of intake moan, but I like that! Not gonna make any HP gain claims, but you can understand that just making air easier for the engine to obtain has got to help some, and with the monster hot temps in Dallas during the summer, every effort to get ambient outside air vs. under the hood hot-as-hell air is a plus!
If AEM ever offers one of their CAI's for this vehicle, will probably get it. But, for now, $12 well spent!!!
have you had any problems with water from rain or puddles entering the in take,, I ask because I made this same type of mod to my dodge ram and I sometimes get water in the intake if i go through a deep puddle to fast!
[quote:0ab9152098="szacherau"]Do you do this to keep the engine cooler? Any concern of pulling in more moisture then norm? I would imagine that the cooling sys is enough for any area.[/quote:0ab9152098]
No, this is to let the engine access ambient temp air vs. the radiator heated air under the hood.
No concern with the humidity level of the air!
My experience with both the '99 Si and the 2k2 Si is that sitting in bumper to bumper traffic in Dallas, in the summer, with the a/c going, with the outside temp in excess of 100, while forcing the engine to source air from under the hood where the a/c & radiator have superheated it to 225+ degrees or more translates to sluggish off-the-line performance. In both cases, adding the ambient air set up eliminated the bogging off idle.
I put 41k miles on the '99 Si with this set up, 12k on the 2002 Si with this set up. No water issues, no any issues - just smoother performance. Caveat is that I was bright enough not to drive into deep standing water with either of those cars, due to the air filters being down below the grille. In the case of my rigged set up on the E, it's up high in the left fender, so not as much worry about deep water being a problem at all.
[quote:d415eca464="medic4lee"]have you had any problems with water from rain or puddles entering the in take,, I ask because I made this same type of mod to my dodge ram and I sometimes get water in the intake if i go through a deep puddle to fast![/quote:d415eca464]
I've never had a vehicle that didn't get some water into the lower levels of the factory-stock intake at some point or another. My '89 Wranger 6-cylinder always had remnants of water/mud/gunk in the stock intake hosing - it got used like a PT boat!
I just removed my Intake Resonator following your instructions. Very easy to do. Not sure how much actual hp it actually adds, but it has to help some. I used a flex intake tube that I bought at Autozone for $9.00. I kept the stock rubber tube connected to the air cleaner housing (the one that was connected to the resonator) and inserted it into the intake tube I bought. I routed the tube back to where the stock plastic inlet was located. I don't think there's as much air flow inside the fender - too many obstuctions (headlights, etc). I also disconnected the negative on the battery itself before moving it around - don't want to take any chances.
Brado
HEK - Not sure what your talking about as far as the air sensor is concerned. Where is it located? If it's inside the resonator box, then it would have to be a mechanical device. I suspect any air sensor on this car would be electronically controlled. I certainly didn't remove anything that was wired up. All I removed was the plastic resonator box. I'll try and post some photos this weekend.
Brado
[quote:416b3c0685="brado"]HEK - Not sure what your talking about as far as the air sensor is concerned. Where is it located? If it's inside the resonator box, then it would have to be a mechanical device. I suspect any air sensor on this car would be electronically controlled. I certainly didn't remove anything that was wired up. All I removed was the plastic resonator box. I'll try and post some photos this weekend.
Brado[/quote:416b3c0685]
Please do...I think we are talking here 2 different things.....like one guy says at work..." is the same but different".... :D :roll:
I took some photos of the modification I made. However, it appears I need a publicly accessible web server to post my photos to. I'll see if I can post them to my homepage, but this may be impossible at the moment with the Comcast takeover of ATT Broadband.
Brado
[quote:3e4629bb3b="brado"]I took some photos of the modification I made. However, it appears I need a publicly accessible web server to post my photos to. I'll see if I can post them to my homepage, but this may be impossible at the moment with the Comcast takeover of ATT Broadband.
Brado[/quote:3e4629bb3b]...
I loaded some pics here...... www.imagestation.com and www.cardomain.com both host pictures for free
OK, I joined ImageStation and made a photo album. The link is: http://www.imagestation.com/album/?id=4289904187
I think you have to be a member of ImageStation to view the photos. If there's a way around this, let me know. On some of the photos, I but a blue arrow pointing to the area of interest.
Hopefully this will be of some help to other Element owners. If more photos are needed, let me know.
Brado
[quote:a7f02f2a46="brado"]OK, I joined ImageStation and made a photo album. The link is: http://www.imagestation.com/album/?id=4289904187
Brado[/quote:a7f02f2a46]
Brado, I see your work....so I'm linking the pics from another site to compare....
and this one I understand...
but how about a picture from the front looking into the engine compartment.....and about the ribs on the hose....uhmmm not sure if the air looses force...turbulence??...maybe???
First of all, how are you getting pictures into the forum?
Secondly, I show a picture from the front grill, where the blue arrow is pointing to the stock plastic air inlet. I cut an oval shaped hole in the vertical part of the plastic radiator cover and shoved the stock inlet into this, I connected the other end of the stock inlet to my overly ribbed intake tube.
I wanted to keep the stock air box, don't particularly like the look of the Injen, etc and don't want the noise.
I will remove the radiator cover and take some photos - will post here when photos are up.
Again, how are you getting photos on here?
Brado
I posted some more photos on http://www.imagestation.com/album/?id=4289904187
On the elementradiatorcover photo, I used a dremel to cut the oval shape.
Elementintake8 is showing the stock plastic intake elbow.
Elementintake7 is showing the same elbow pulled back from the grille for a better photo.
Elementintake6 is an overhead view of the elbow in its normal position.
Hope this helps explain what I did.
Brado
[quote:14ba99aa6c="brado"]I posted some more photos on http://www.imagestation.com/album/?id=4289904187
Brado[/quote:14ba99aa6c]
Brado check your PM....You don't have a filter ???? or are you using the stock one...?
1 - 20 of 41 Posts
