I want my E to source ambient temp air vs. the hot air under the hood. I studied the drawings of the intake system, and realized how easy this would be.
1). Take off the intake resonator. This involves removing the two 10mm bolts, clearly visible, that hold it to the driver's side inner fender. Also temporarily take off the negative chassis ground (goes from neg battery post to driver's inner fender, also 10mm). Take off battery hold down clamps and move battery forwards and parallel to the radiator.
2). Remove the 10mm bolt that holds the electrical box (directly above where the resonator sits) to the fender so you can just ease this up and out of the way.
3). Remove the rubber hose between the resonator and the air filter box. It just pops off. Lift out the resonator, working it out between the battery, fender and power box.
3). Reinstall battery clamps and ground strap. Reinstall the bolt for the power box.
I then went to AutoZone and got auto intake hose, 3" id, part # P319-325. It's about 2.5 - 3' long. It slips over the inlet to the air cleaner box, then can be routed over into the driver's side fender well through the large hole where the resonator used to sit. It has little snap clips on both ends, so you can secure it to the filter box. I will probably go back with some zip ties and secure the end of the hose in the fender.
Hose cost: $11.99 and labor time of about 15 minutes.
Result: You will hear a bit of intake moan, but I like that! Not gonna make any HP gain claims, but you can understand that just making air easier for the engine to obtain has got to help some, and with the monster hot temps in Dallas during the summer, every effort to get ambient outside air vs. under the hood hot-as-hell air is a plus!
If AEM ever offers one of their CAI's for this vehicle, will probably get it. But, for now, $12 well spent!!!
