Help!!!
Hi! I have a tangerine 2006 EX-P 4wd AT and I'm a total klutz. :roll:
I need help!
I tried this mod and it took me a long time because I have the 4wd so there were the extra relay boxes behind the glove compartment and not much room. After I got the first male connector from the homemade connector into the slot, the other switch touched against the little metal thing on the front of the relay box and sparked! I finished installing it, but the rear outlet didn't work at all.
So I pulled the homemade connector out and replaced the relay plugs that were there in the first place. Neither the front nor the rear outlet worked any more even with the car started. I checked the fuses beneath the hood and steering wheel and found that the fuse for the front power outlet (the one under the steering wheel) had blown out, so I replaced that. Now the front outlet works with the car turned on but the rear one still doesn't work at all.
I learned my lesson and know I'm too big a klutz to do this on my own anymore, so my dad said he'd look at it this weekend for me. Does anyone have any ideas or advice on what's wrong with the rear outlet now? I didn't see any other blown fuses. Do you think we need to replace the switch or something?
I can't afford to take it in to Honda right now, so I'd really appreciate any ideas you have. I feel so bad about hurting my poor car. THANKS!!!!
