1 - 14 of 14 Posts
I change the 4 motor mounts ,clean the crc throtle and body intake and still making rottling noyse they say i have to wait a least a couple of weeks for the mounts to settle will see what happen , i got new tires , new battery lets hope that is it, and there os a noyse coming from the right back tire they say it was the calippers were locked they change them and the noyse is better bit still there help?
If it is still making the same noise nothing has changed and if worn you would notice an imediate improvement so look to the the exhaust hitting somewhere,or more than likely one of the sway bar Links is broken and rattling in its housing. check your exhaust hangers and grommets. See if you can replicate sound by bouncing rear bumper while having another person look underneath to determine where sound is at.
When i'm driving starts suddenly and continues for a while then stops and then starst again thats the rattling noise is like when you go to walmart handling a cart and the wheel are loose .
The other thing i got is i was trying to change the lights from the cluster speedometer the wouldn't fit so i pull a protection from the back and put them directly so i put them in the car and look at a smoke coming out , so turn the car off ,took the cluster out and reposition the lights with the protection but strongly and they worked but the clustes was bad so i went to a "specialist" and find me a used replacement , that's the only thing he did cause he didn't fix the miles and now the D light is blinking so is causing my battery to shut down only a week new.
I change the timing belt and tensioner and still making noise in front under motor is a vibration like rattling if I recorded on sound almost unhearable but it do shows the vibration on the voice recorder but don't know how to share it here
1 - 14 of 14 Posts
