2005 Element DIY Powered Trailer Harness Instructions
2035 Views 8 Replies 1 Participant Last post by  mariekonkin
05 Element trailer harness wiring. Better late than never. Called Honda dealer in Saskatoon for 05 trailer harness. His price $280CDN. My reaction…not printable. Knowing the price from HandA I decided to figure out how to wire it myself. Have Alldata database for all Honda 1986 to 2008. Dug out the wiring diagrams and started to trace wiring. Basically came to the conclusion that the plug under the dash controls the trailer harness. The rear quarter panel connector that the Honda service manual as well as Alldata refers to is non existent. It is actually the connector on the Honda powered convertor “C” referred to in Enigma’s post.
Basically needed a male connector to plug in to the connector under the dash. I'll dig a little more to see if a T-One powered connector with the correct connector is available and thus would be plug and go, 03-04 Element and 03-04 CRV plugs would be the same but would be non-powered. Went to a salvage yard and found a 2004 CRV with a non powered trailer harness with the correct plug, but also noticed the tail light connectors for the CRV are the same connectors as the Element under dash connector. So took the whole rear tail light harness as well as the hitch harness from the CRV for $25. I could have used the CRV non powered harness but decided to err on the side of caution and use a powered convertor. Took the CRV tail light connectors and disassembled them to get the pigtails for the under seat and rear Element connectors.
Unlock connector wings (secondary locks), in order to remove pigtails, then look for a tiny tab (primary lock) to free the pigtail.
Went to Canadian Tire and bought a Reese 118187 powered convertor, on sale for $25, soldered the pigtails to the convertor wiring on the car side and inserted the pigtails in the correct slots, taking the power for the Reese convertor from the #5 pigtail that is from the unused #8 fuse (there is no fuse originally so stick a 7.5 amp mini fuse in that slot) under the hood.
To save futzing around with the under front seat Honda connector to the rear connector of the Element you could just run the trailer side of the Reese convertor straight out to the trailer. But me being a dummy, I took the dummy female connector from under the seat as well as the male connector in the spare tire well of the Element (I'm surprised Honda put both connectors in both locations for no charge) and populated the pigtails, which is why I needed the harness from the CRV, for all the pigtails. Wired the trailer side of the Reese convertor to the under seat connector and the ground wire to the floor pan. Then wired the 4 flat connector to the connector in the back of the Element.
Plugged the powered convertor to the under dash plug and voila trailer harness working.
Not sure why Reese or Hopkins were unable to devise a hookup for the 05 Element, but the rear trailer harness connector on the 2004 CRV is the same as the connector under the 05 Element dash, so if you make sure the wiring to both connectors match, a non powered convertor from 2003-04 Element should also work, (only if you have max one bulb on each side) then bypass the under seat to rear Element connector and extend the trailer side out to the trailer. Possibly it was the non existent rear quarter panel connector that threw them off.
Attached connector views, under dash, under front seat, Element rear.
Wiring diagram 118-4
No luck finding a powered convertor with the correct male connector for the under dash 05 Element. Looking at the non-powered Hopkins convertor that I found for the 04 CRV, the CRV male plug wiring matches up with the 05 Element under dash plug minus the #5 power wire from the #8 fuse. Basically an 03-04 Element/03-04CRV non powered convertor will plug n play, add an extension to the trailer side of the Hoppy to reach the rear tailgate and you will avoid having to use clips or rewire. Just have to make sure to keep trailer lights at 2.1 amps. Most 1500 lb trailers won't be lit up like a semi.
