Hello All,
I have a 2005 MT5 AWD. I have multiple issues.
1.) Shift linkage is knotchey and loud. Upshift from 1st to 2nd - I usually have to just let the gear "drop in". I can force it in with no grinding, but there is annoying resistance. Downnshift from 3rd to 2nd is OK. I have lubricated the shift linkage and changed the trans. fluid and added the Honda conditioner with no improvement. Also changed the cluch fluid. Other gears shift fine up or down.
2.) Very slight vibration when accelerating in 2nd gear at low RPM. It is right at the low end. Feels like it is RPM related and not speed related.
Actions: I've had my Honda mechanic ( expert of 35 years ) try to diagnose the problem. He does not think it is clutch or slave cylinder related. He has not worked on very many AWD Elements and he is worried about opening a "can of worms". I agree with his causion and I've just been living with it. I'm thinking it may be drive shaft related, maybe the balancing? I've had the car since new and I'm sure these issues did not exist when I bought it.
