Hi! Hoping to get some advice on diagnosing a stall issue I've been having with my Element recently--
Description of problem: when the engine is cold (usually on first start-up, but not all the time & more prominent in cold weather), if I put the car into gear (reverse or drive) pretty quickly without letting it warm up, the engine stalls. I have noticed that letting it warm up for 1-5 minutes usually prevents this issue, and I can sometimes pull it out of the stall by hitting the accelerator hard/giving it gas. Before it stalls, it becomes very rough and then dies. When it does stall, only the battery light on the dash comes on (i.e., no check engine light). The most recent time this happened, I had a hard time getting the engine to start after the stall and the oil pressure light turned on as well as the battery light (might be a red herring, might not be). Outside of this stall issue, the car has appeared to operate fine ~99% of the time (including starting up fine). I've had one issue with lag on acceleration from a stop with the engine warm (enough of a lag to think "wait it's not moving" and then it moved). I've had trouble getting it to turn on at all (i.e., no start then stall. just no start at all) probably a total of 2 times. At a stop when the engine is warm, the car sometimes idles rough around 1k rpm, and otherwise idles between 1k- 500 rpm (honestly only started watching rpms recently so unsure if 1k-500 rpm is low relative to before I started having this issue).
I took it to a shop and they couldn't recreate the problem. They said it might be a bad throttle body and quoted me >$1k to replace it. I declined since I would rather not pay $1k without being certain that the throttle body is the actual issue.
Other maybe relevant information:
1- alternator replaced ~20k miles ago
2- replaced the battery in Feb (this problem has spanned a bad & good battery; was really hoping it could be battery related...)
3- new aftermarket catalytic converter as of October 2022. The original was stolen in 2020, and the aftermarket cat. put in after the theft went bad (was driving with that for a while; only knew it was bad when I failed emissions but no code thrown ever)
4- recent oil change and oil level was fine when I checked after the light turned on at the most recent stall.
5- 2006 EX-P with 133615 miles. AWD, automatic transmission.
6- haven't noted how much gas was in my tank at every stall, but most recently it was at a 1/4 tank. I don't usually let it get much lower than 1/4 tank in general.
Any advice on diagnostics or (simple) things to try to correct this problem would be really appreciated! I'm a grad student with very little car experience but willing to youtube most things & would love to try to make this a less expensive problem!
