Just an FYI: the '07+ Element all have the same struts so the springs will work for all Elements. I would be easier to collect E owners this way. Do you have any pricing info for poeple? How many do you need?
just so ya know. strut wise 03-10 element uses 52611-SCV-A02 strut in rear SC uses 52611-SCV-A91 thats the bare shock absorber no spring etc.
07-10 element uses 51605-SCV-A05 (R) 51606-SCV-A05 (L) front bare shock absorbers
07-10 SC uses 51605-SCV-A92 (R) 51606-SCV-A92 (L) front bare shock absorbers
the body might be the same but the length and damping is not the same. unless you physicaly had all the parts in one place its unknown what will fit and what wont
also whats the drop on SC model springs? it would be almost an inch more if you could fit them to a non SC. and the normal 1.5 drop etc would be barely anything on a SC
The sc has its own part number from eibach, it is not shared with the lx/ex. If you do some research you will find pics of sc's on here with them on. They lower the sc about 1.5" over the stock which is 25mm(approx. 1") for a total of 2.5" over all from the lx/ex.
