Hello, for sale by owner is our 2008 Honda Element EX AWD. Highest trim level with AWD, moonroof and updated model year with 5-speed auto transmission for improved fuel economy.
Runs and drives great with no creaks or rattles. Suspension is tight and vehicle tracks straight. Transmission shifts smooth. AC blows cold and heat runs hot. No check engine lights etc!
In excellent mechanical condition and meticulously maintained with oil and filter changes every 5k miles. Extensive maintenance records as per below:
• Dec 2022 @ 275k miles: All fluids changed - engine oil and filter, coolant flush, brake fluid flush, transmission fluid drain and fill, differential fluid drain and fill.
• Jan 2023 @ 276k miles: Replaced the following suspension components - sway bar bushings, sway bar end links, both rear CV axles, performed an alignment and replaced all four tires with M+S (Mud & Snow) All-Season Tires [Kumho Crugen HT51s].
• Feb 2023 @ 277k miles: Replaced the VTEC Solenoid and performed another engine oil and filter replacement to improve fuel economy and prevent rough idling.
Washed daily with touch-free car wash pass. Exterior in good condition with minor rust spot and common WI surface corrosion as pictured. Interior in good condition with common tear in drivers seat. Vacummed weekly, non-smokers.
VIN: 5J6YH28708L019676. Clean title in hand. Cash ONLY! You pick up in Eau Claire, WI 54701. Will NOT deliver or ship...
If the ad is up, it is still available. Thanks for reading!
Tags: Honda, Toyota, Ford, Chevrolet, SUV, AWD, 4WD.
