I would say no, because there is more curve on the rooh of the pre "09" E's
I am looking to add this to my "11" LX, anyone done this?
Lizzurd,The shape of the roof has not changed since 2003.
The only physical changes to ther roof panel were the revised mounting brackets for the 2009+ roof console.
Lizzurd,
Looking at 2006 & 2011 roof lining pic below, size of mounting holes, size of bracket, qty of screw for storage, has increased significantly form pre-2009 to 2009+.
Mounting a larger bracket/storage which required more screw holes, to a smaller hole which has less screw holes is going to be interesting. :roll:
2006 Roof Lining:
2011 Roof Lining:
Moved your thread into here. Short answer is it will NOT work.Does anyone know if the overhead compartment on a 2009 can be placed on a 2007? If so, what parts do you have to buy to install it?
Hello,
Has anyone tried to install an overhead console (#32 in picture) from a 2009 EX into a 2008 LX?
Suggestions?
10 charactersMoved your thread into here. Short answer is it will NOT work.
Read the above to find out why.
