1 - 1 of 1 Posts
I had looked for sum of this stuff before and couldn't find it. On the honda owners link there it was!:shock:
So I thought I would share.
Use the links below to view complete specifications for your Honda.
Engineering Transmission
Body/Suspension/Chassis Exterior Measurements
Interior Measurements EPA Mileage Estimates/Capacities
Safety Exterior Features
Comfort & Convenience Seating
Audio Systems Instrumentation
Engineering
Engine Type: In-Line 4-Cylinder
Engine Block/Cylinder Head: Aluminum-Alloy
Displacement (cc): 2354
Horsepower @ rpm (SAE net): 166 @ 5800
Torque (lb-ft @ rpm): 161 @ 4000
Redline (rpm): 6500
Bore and Stroke (mm): 87 x 99
Compression Ratio: 9.7: 1
Valve Train: 16-Valve DOHC i-VTEC®
Multi-Point Fuel Injection
Drive-by-Wire™ Throttle System
CARB Emissions Rating: LEV-2
Direct Ignition System with Immobilizer
100K +/- Miles No Scheduled Tune-Ups*
* Does not apply to fluid and filter changes. May vary with driving conditions. Please see your Honda dealer for details.
Transmission
5-Speed Automatic Transmission Gear Ratios
1st: 2.786
2nd: 1.614
3rd: 1.082
4th: .773
5th: .566
Reverse: 2.000
Final Drive: 4.5
Unit-Body Construction
Control-Link MacPherson Strut Front Suspension
Compact Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear): 30.0 / 21.0
Variable Power-Assisted Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: 3.26
Steering Ratio: 16.2
Turning Diameter, Curb-to-Curb (ft.): 34.9
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.1 / 11.1
Wheels: 16" Alloy
All-Season Tires: P215 / 70 R16 99S
Wheelbase (in.): 101.4
Length (in.): 169.9
Height (in.): 70.4
Width (in.): 71.6
Track (in., front/rear): 62.1 / 62.3
Ground Clearance (in., unladen): 6.9
Approach/Departure Angles: 25.6°/26.3°
Curb Weight (lbs.): 3540
Towing Capacity (lbs.): 1500
Headroom (in., front/rear): 43.3 / 38.0
Legroom (in., front/rear): 41.0 / 39.1
Shoulder Room (in., front/rear): 57.1 / 52.2
Hiproom (in., front/rear): 55.0 / 47.6
Cargo Volume (cu. ft., behind 2nd-row): 25.1
Cargo Volume (cu. ft.,maximum): 74.6
Passenger Volume (cu. ft.): 103.6
Seating Capacity: 4
EPA Mileage Estimates*/Capacities
City/Highway/Combined: 20 / 25 / 22
Crankcase (qt.): 5.6
Coolant System (qt.): 7.5
Fuel (gal): 15.9
Required Fuel: Regular Unleaded
* Based on 2010 EPA mileage estimates, reflecting new EPA fuel economy methods beginning with 2008 models. Use for comparison purposes only. Do not compare to models before 2008. Your actual mileage will vary depending on how you drive and maintain your vehicle.
Safety
3-Point Seat Belts at all Seating Positions
Front 3-Point Seat Belts with Automatic Tensioning System
Driver's and Front Passenger's Seat Belt Reminder
Dual-Stage, Multiple-Threshold Front Airbags (SRS)
Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS)
Side Curtain Airbags with Rollover Sensor
Anti-Lock Braking System (ABS)
Electronic Brake Distribution (EBD)
Vehicle Stability Assist™ (VSA®) with Traction Control
Brake Assist
Daytime Running Lights (DRL)
Tire Pressure Monitoring System (TPMS)
Side-Impact Door Beams
Lower Anchors and Tethers for CHildren (LATCH):Lower Anchors (2nd-Row All), Tether Anchors (2nd-Row All)
Exterior Features
Side Cargo Doors
Variable Windshield Wipers
Rear Window Wiper/Washer
Roof-Mounted Antenna
Remote Entry System
Power Side Mirrors
Green-Tinted Glass
Rear Privacy Glass
Clamshell Tailgate
Alloy Wheels
Multi-Reflector Halogen Headlights
Chrome Exhaust Finisher
Air Conditioning with Air-Filtration System
Power Front Windows with Auto-Up/Down Driver's Window
Rear Ventilation Windows
Power Door and Tailgate Locks
Steering Wheel-Mounted Controls: Cruise/Audio
Adjustable Steering Column
Instrument Panel-Mounted Shifter
Driver's and Front Passenger's Vanity Mirrors
Sliding Sun Visor Extensions
Overhead Storage Compartment
Map Lights
Dome Light
Urethane-Coated Utility Floor
Beverage Holders, Front and Rear
12-Volt Power Outlet: Front / Rear
Door-Pocket Storage Bins, Rear with Bottle Holders
Driver- and Passenger-Side Seatback Pockets
Driver-Side Seatback Bungees, Front and Rear
Rear Window Defroster
Rear-Seat Heater Ducts
Cargo Area Tie-Down Anchors (4)
Cargo Area Storage Bins
Cargo Area Hooks (2)
Cargo Area Light
Center Console: Removable Cooler
Seating
Driver's Seat with Manual Height Adjustment
Water Resistant FXC™ (Fabric for Extreme Conditions) Seat Fabric: Front and Rear
Adjustable Head Restraints
Driver and Passenger-Side Armrests
Removable, Flip-Up Rear Seats
Fold-Flat-Capable Seating
Audio Systems
270-Watt AM/FM/CD Audio System with 7 Speakers including Subwoofer
MP3/Windows Media® Audio (WMA) Playback Capability
MP3/Auxiliary Input Jack
XM® Radio
CD Text Display Capability
Instrumentation
Backlit Gauges: Blue
Tachometer
Digital Odometer and Digital Trip Meters (2)
Tire Pressure Monitoring System (TPMS) Indicator
Vehicle Stability Assist™ (VSA®)-On Indicator
Maintenance Minder™ System
Door-/Tailgate-Open Indicator
Fuel and Coolant Temperature Indicators
Low-Fuel Indicator
Low-Oil-Pressure Indicator
Exterior Temperature Gauge
Passenger-Side Side Airbag-Off Indicator
Fuel Cap Indicator
1 - 1 of 1 Posts
