I've been looking into snow tires and rims and noticed a significant savings on 15" rims over 16". The 235/75/15 size seems to be about the same as a 235/70/16 for about 70 dollars less. I've seen the size mentioned in some of the threads here but no examples of real word application other than rubbing issues with improper offset. Anyone have firsthand experience with this tire size?
Assuming no suspensions modifications, I would look for a wheel that is 6.5" to 7" wide that offers a +38mm offset. A wheel with these dimensions should work without rubbing with tire size 235/75-15. You'll also want to make sure that which ever wheel you get into is properly load rated and has enough brake clearance.
Please double think the 235 wide tires for the winter, I had 235's on mine last year and was all over the place, they were good blizzaks but my wifes 303hp impala ss had 215 wide blizzacks and were used at the same weight of the vehicle and I went thru everything, try to go with a smaller width, it really does help cut thru the snow.
