1 - 2 of 2 Posts
saw this and was interested in doing it: http://www.ccmoffroad.com/shop/index.php?l=product_detail&p=18
has anyone done it? or know anyone who has? could it mess anything up on the car? would my 7 year 100,000 mile warranty from honda still be good? is $500$ good?
Honda Element 3" Lift Kit :
2003-2009 Honda Element
CCM Offroad and Performance has designed and built the best quality and strongest lift kit on the market. This is the FIRST BOLT ON lift kit system manufactured for the Element.
--- 1/4" Steel which is CNC Laser Cut for a very tight tolerance fit.
--- 1/4" Wall High Strength Spacer Tubing for a very high strength unit.
--- OEM Style Grade 10.9 Pressed in Studs This keeps the bolts from weakening during the weld process.
--- Turn Table High Frequency Pulse Welded. Insures for proper penetration of all the weld area without the need for starts and stops.
--- Powder Coated semi gloss black for a great looking long lasting durable finish (NOT just rattle can painted or sprayed with automotive undercoat.)
--- Complete with all parts needed to correct the alignment after the install. New front camber bolts and new adjustabe upper control arms for the rear. (Alignment parts made by Specialty Products.)
--- Complete and easy to follow installation instructions for a simple straight forward install.
--- LIFETIME GUARANTEE!!!!
Fits: 2003, 2004, 2005, 2006, 2007, 2008, 2009 Honda Element
1 - 2 of 2 Posts
