5AT slow/hard shifting troubleshooting
291 Views 8 Replies 4 Participants Last post by  seagiant
I have an 07 5AT
I am having slow, hard shifts from 1-2 and 2-3 as well as occasional shudder when letting off the gas.
I've heard trans solenoid is most common issue . im Hoping a
Trans Fluid drain and fill +
Trans fluid filter change +
trans solenoid replacement
Will solve it.
Has anyone else had luck with these three things improving their shifting on an 07+ 5AT ?
  • Like
Reactions: 1
Try the drain and fill 3x procedure before throwing other parts at it. It’ll take a few weeks if you wait a week between each change, to give time for the fresh fluid to do its thing
  • Like
Reactions: 2
Welcome to the EOC Gggman! :)
I agree with DCM. Try all the simple fixes first before moving on to the more difficult (and costly) repairs.
  • Like
Reactions: 1
Hi,
Change the little Filter when you do the fluid, it's there.
Had a old Parts Guy at my Dealer tell me it did not exist on the E!
Had to make him look harder for it on the Computer, it's there!
  • Like
Reactions: 1
Thanks, I might try a couple drain and fills. I just bought the car and the trans fluid already seemed new so I'm worried now that they flushed the fluid to hide any burning/metal in the fluid, but it's too late now. There doesn't seem to be any burning or metal in it at the moment.
I was considering skipping the drain and fill since the fluid already looks new and going straight to the solenoid and filter replacement, but i might try doing a drain and fill one or two times.
It seems like the solenoid can be found for around $80 and the filter for around $40. I heard it's important to get the OEM trans filter because theres a special part inside it that only the OEM one has. 12 quarts of the trans fluid seems to be around the same price as those 2 parts so i'm debating just trying the parts first since the fluid already looks new.
You can easily test your solenoids, there are YouTube vids. If they give a solid click with 12V applied, they’re good so don’t waste your money replacing them.
  • Like
Reactions: 1
Good idea (y)
Hi,
See if you have a Honda Dealer near by.
I actually have a good one, and use them for parts!
  • Like
Reactions: 1
