Perusing through the many threads on the front accessory always on mods, I had a thought.
Instead of doing a bunch of rewiring, would it be possible to do the following:
Use an Add-a-Circuit on Fuse #2 (which controls the rear outlet)
Take the lead from the Add-a-Circuit and vampire splice into the Yel/Wht wire coming out of Fuse #18.
Remove #18 fuse.
This should (in my non-electrical mind) give you always on fused power to the front accessory socket.
Thoughts?
Remove #18 fuse.
Thoughts?
