Finally got around to fixing up my a pillars. I've had them cut up and diced to pieces for about a year and a half. Put about 2 or 3 hours of work on them, fixing all previous damage and doing the build out. It was pretty dang easy once I finally got to it. Here are two quick cell phone pics. You can see where I cut out the factory tweeter and then made a new hole for some other tweeters I had. To make the ring for the new tweeter I just used 2 hole saws to cut out the ring. I cut out another hole further forward (after playing with tweeter positions) with the same hole saw. Then I used some Loc-Tite 2 part epoxy that I picked up at Home Depot to fasten them. After a lot of sanding/building up/sanding/bondo/ etc, I covered em in vinyl. This was my first experiment with vinyl. It turned out to be pretty easy to use. MUCH less work than trying to prep for paint. We'll see how it does in the long run. I really like the black.
Hoping to get started on the 13Av.2 build this weekend.
