1 - 8 of 8 Posts
hi everyone i use my element for camping and once you are in the car and close all of the doors its hard to get out.my simple solution was to remove the rear inside panel then i drilled a one inch hole in the center so i can put my finger in and move the lever.it works mint i can even close it by pulling it .be sure you make the right measurements before you drill it.and the hole is small that it doesnt look that cheesy.but to me the benifits outway the cosmetic damage.i wish some company would make a bolt on latch.
Do you push or pull the lever or is it sideways action? I was thinking the same thing but looking for an aftermarket latch to do the same thing. At least I can get a plastic or rubber grommet from Home Depot to dress a simple hole.
You made me curious.
How much room is there under the plastic? Do you think an actuator would fit under there? I was thinking of making some device that would unlatch the hatch by the push of a button.
If it looks feasible, and I can get it to work, I will post a how-to.
Thanks.
1 - 8 of 8 Posts
